[PROJ] PROJ 8.1.0RC1 & PROJ-data 1.7RC1
Thomas Knudsen
knudsen.thomas at gmail.com
Tue Jun 29 10:16:14 PDT 2021
+1 /thomas
Den tir. 29. jun. 2021 kl. 16.10 skrev Kristian Evers <
kristianevers at gmail.com>:
> PSC Members,
> No issues with the two release candidates have been reported so I hereby
> motion that
> PROJ 8.1.0RC1 and PROJ-data 1.7RC1 be promoted to their final versions.
> I’ll start with my +1.
> /Kristian
> > On 25 Jun 2021, at 18:31, Kristian Evers <kristianevers at gmail.com>
> wrote:
> > All,
> > I have prepared release candidates for PROJ 8.1.0 and PROJ-data 1.7.
> Download them here:
> > http://download.osgeo.org/proj/proj-8.1.0RC1.tar.gz
> > http://download.osgeo.org/proj/proj-8.1.0RC1.zip
> > http://download.osgeo.org/proj/proj-data-1.7RC1.tar.gz
> > http://download.osgeo.org/proj/proj-data-1.7RC1.zip
> > See the PROJ release notes below. The PROJ-data release includes two new
> grids:
> > fr_ign_RAF18b.tif and au_ga_AGQG_20201120.tif. In addition the
> predecessor for the
> > latter grid, au_ga_AGQG_20191107.tif, has been removed.
> > Please test the two release candidates and report back your findings
> either to the
> > mailing list or in a GitHub issue.
> > /Kristian
> > 8.1.0 Release Notes
> > Updates
> > + Database
> > o Update to EPSG v10.027 (#2751)
> > o Decrease DB size by using WITHOUT ROWID tables (#2730) (#2647)
> > o Add a ANALYZE step during proj.db creation allowing for
> > faster lookups (#2729)
> > o Added a PROJ.VERSION metadata entry (#2646)
> > o Added NGO48 (EPSG:4273) to ETRS89 (EPSG:4258) triangulation-based
> > transformation (#2554)
> > o Additions to the norwegian NKG2020 transformation (#2548)
> > o ESRI projection database updated to version 12.8 (#2717)
> > + API additions
> > o Added proj_get_geoid_models_from_database() function that returns a
> list of
> > geoid models available for a given CRS (#2681)
> > o Added proj_get_celestial_body_list_from_database that returns a list
> > of celestial bodies in the PROJ database (#2667)
> > o Added proj_get_celestial_body_name() (#2662)
> > + Various improvements
> > o proj_trans/cs2cs: If two operations have the same accuracy,
> > use the one that is contained within a larger one (#2750)
> > o Share SQLite database handle among all contexts (#2738)
> > o Add proj/internal/mutex.hpp as compat layer for mingw32 for
> std::mutex (#2736)
> > o projsync: make it filter out files not intended for the current
> version (#2725)
> > o Improvements related to DerivedVerticalCRS using Change Unit and
> > Height/Depth reversal methods (#2696)
> > o Update internal nlohmann/json to 3.9.1, and add a CMake option to
> > be able to use external nlohmann/json (#2686)
> > o createFromUserInput(): change name of CRS built from URN combined
> references to match the convention of EPSG projected CRS (#2677)
> > o Parse compound id with two authorities, like ESRI:103668+EPSG:5703
> (#2669)
> > o Added projinfo option --list-crs (supports --area) (#2663)
> > o Added support for hyperbolic Cassini-Soldner (#2637)
> > o Added capability to get SQL statements to add custom CRS in the
> database (#2577)
> > Bug fixes
> > o Fix 'Please include winsock2.h before windows.h' warning with msys
> (#2692)
> > o Minor changes to address lint in geodesic.c (#2752)
> > o BoundCRS::identify(): avoid incompatible transformation for
> > WKT1 / TOWGS84 export (#2747)
> > o proj_create(): do not open proj.db if string is a PROJ string,
> > even if proj_context_set_autoclose_database() has been set (#2735)
> > o Fix export of transformation to PROJ string in a particular situation
> > where CompoundCRS are involved (#2721)
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20210629/353f7d01/attachment-0001.html>
More information about the PROJ
