[PROJ] Creating projection *not* from full init string?
Matthew Woehlke mwoehlke.floss at gmail.com
Tue Mar 9 11:43:47 PST 2021
On 09/03/2021 13.33, Even Rouault wrote:
> Le 09/03/2021 à 19:18, Matthew Woehlke a écrit :
>> In PROJ 4, 4326 is "+proj=longlat +datum=WGS84 +no_defs +ellps=WGS84".
>> If I use that with proj_create, I get something usable. What's the
>> difference?
> PROJ >= 6 now makes a difference between a CRS and a coordinate
> operation. A PROJ string without +type=crs is assumed to be a coordinate
> operation, and with +type=crs to be a CRS.
> The old PROJ.4 definitions without +type=crs depending on the context
> could be used as a CRS definition or a coordinate operation. PROJ >= 6
> now requires to be explicit to avoid that confusion. You can't use a CRS
> like "EPSG:4326" with proj_trans(). That doesn't make sense. A CRS
> doesn't define a coordinate operation by itself.
I sort-of get that, but I don't think you actually answered the
question. What does "+proj=longlat +datum=WGS84 +no_defs +ellps=WGS84"
mean than I *can* use it with proj_trans?
>> p.s. How do I get that definition in PROJ 5? In PROJ 4, I could use
>> pj_get_def. (See also https://stackoverflow.com/questions/66533885.)
> Use proj_as_proj_string(). That can work on both CRS and coordinate
> operation (when there's a single coordinate operation actually contained
> in proj_create_crs_to_crs() )
Why is *that* not documented as the replacement for pj_get_def?
Matthew
More information about the PROJ mailing list
