[PROJ] proj_trans swaps X and Y?
Matthew Woehlke mwoehlke.floss at gmail.com
Wed Mar 10 06:07:58 PST 2021
I'm trying to convert between coordinate systems using
proj_create_crs_to_crs and proj_trans.
In PROJ 4, coordinates are always in x,y,z (easting, northing, altitude)
order. I just stuff my coordinates in and read them back, possibly with
some conversion between degrees and radians, and everything Just Works.
If I try to do this in PROJ 5, it fails. As best as I can tell, lat-lon
coordinate systems expect input, and provide output, as y, x, z.
Given that all I know is the EPSG, how do I determine the proper order
in which to provide my inputs and read my outputs?
Matthew
More information about the PROJ mailing list
