[PROJ] Describing custom vertical datums in wkt
    Even Rouault
    even.rouault at spatialys.com
    Fri Mar 26 09:58:14 PDT 2021
Eric,
Besides a few minor issues in the below WKT (use of single quotes, or
non-ASCII double quote characters), more fundamental remarks:
- I don't think DerivedVerticalCRS is the appropriate modeling.
http://docs.opengeospatial.org/is/18-010r7/18-010r7.html in §3.1.14
mentions: "A derived coordinate reference system inherits its datum or
reference frame from its base coordinate reference system.", so you
can't have the derived CRS having VDATUM["NOAA Chart Datum"] and the
base CRS VDATUM["NAD83(2011) Height"]. And if you look at the grammar at
http://docs.opengeospatial.org/is/18-010r7/18-010r7.html#120, VDATUM[]
is not allowed for the derived vertical CRS, and when PROJ re-exports to
WKT2 this definition, it will omit it.
- One could question too if the derivation is a conversion. §14.2.1
mentions "Because by definition coordinate conversions are exact, the
attribute operation accuracy is not relevant and excluded from the
deriving conversion WKT string". Using grids is probably a big unusual
to define a conversion
- you can't use EPSG:6319 that is the Geographic 3D CRS as a (base)
vertical CRS. Ellipsoidal heights in ISO-19111 can't exist as standalone
vertical CRS. They must be associated with the horizontal coordinates.
- the proper model would probably be to define a NOAA Chart Datum
vertical datum and vertical CRS, and define a transformation between
EPSG:6319 and the NOAA Chart Datum vertical CRS. You could reference
that transformation in a GEOIDMODEL[] node attached as a child of the
VERTCRS[].
- besides importing/exporting/querying the attributes, PROJ will not be
able currently to do anything useful (ie compute a PROJ pipeline between
that and another vertical CRS) with a derived projected CRS.
Even
Le 26/03/2021 à 16:06, Eric Younkin - NOAA Federal via PROJ a écrit :
> Hello,
> As we move to registering our vdatum grids in EPSG, we needed to
> develop a stop gap solution, describing our custom datums in WKT for
> archival.  These would be derived datums based on elheight or geoid
> height, with proj vgrid pipelines applied to get to water level
> datum.  We are thinking about using something like this:
> VERTCRS["NOAA Chart Datum",
>                   BASEVERTCRS["NAD83(2011) Height",
> VDATUM["NAD83(2011) Height"],
> ID["EPSG",6319]],
>                   DERIVINGCONVERSION["NAD83(2011) Height to NOAA Mean
> Lower Low Water",
>  METHOD["VDatum_VXXX gtx grid transformation",
> ID["EPSG",1084]],
> PARAMETERFILE['g2012bu0', 'core\\geoid12b\\g2012bu0.gtx',
>                                                   ID[“NOAA VDatum”,
> “NAD83 to Geoid12B”, “10/23/2012”]],
> PARAMETERFILE['tss', 'CAORblan01_8301\\tss.gtx',
>                                                   ID[“NOAA VDatum”,
> “Geoid12B to Tss", “06/20/2019”]],
> PARAMETERFILE['mllw', 'CAORblan01_8301\\mllw.gtx',
>                                                   ID[“NOAA VDatum”,
> “Tss to Mean Lower Low Water”, “06/20/2019”]]],
>                     VDATUM["NOAA Chart Datum"],
>                     CS[vertical,1],
>                           AXIS["gravity-related height (H)",up],
>                           LENGTHUNIT["metre",1]]
> I know this isn't something we could use in PROJ in the same way that
> a registered EPSG reference could, but we could at least have
> something describing what we do for archival. I'm thinking of building
> some code to manually translate a move between two of these WKT
> strings into a pipeline operation.
> Hopefully that made sense.  Please let me know if you have any
> suggestions.
> Thanks,
> Eric
> Eric Younkin
> Physical Scientist
> NOAA OCS, Hydrographic Systems and Technology Branch
> 1315 East-West Highway
> N/CS11, Room 6604
> Silver Spring, MD 20910
> Office: 240-847-8208
> Cell: 828-331-8197
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20210326/2fd36322/attachment.html>
More information about the PROJ
