[PROJ] Describing custom vertical datums in wkt
Greg Troxel
gdt at lexort.com
Fri Mar 26 10:49:11 PDT 2021
I suggest that you separate
preparing what you would like in the EPSG database
and
getting EPSG to accept it
I am pretty sure that once you have the content that you would submit,
you can modify a copy of proj to add a second file that is loaded into
the proj database at build time, and thus have a proj installation that
has your datum and transform definitions even though EPSG has not yet
accepted them. Probably this can be done with a script on an
installed copy too.
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20210326/154dc507/attachment.sig>
More information about the PROJ
