[PROJ] PROJ 8.0.1RC1 and PROJ-data 1.6RC1
Even Rouault even.rouault at spatialys.com
Mon May 3 10:37:48 PDT 2021
+1 Even
Le 03/05/2021 à 19:36, Kristian Evers a écrit :
> Apart from a little mishap with the initial upload of the PROJ files no issues
> with the two release candidates has been reported, so I hereby motion that
> they be promoted to their final versions.
> I’ll start with my +1
> /Kristian
>> On 28 Apr 2021, at 12:49, Kristian Evers <kristianevers at gmail.com> wrote:
>> All,
>> I have prepared candidates for the upcoming PROJ 8.0.1 and PROJ-data 1.6 releases.
>> The packages are available from
>> http://download.osgeo.org/proj/proj-8.0.1RC1.tar.gz
>> http://download.osgeo.org/proj/proj-8.0.1RC1.zip and
>> http://download.osgeo.org/proj/proj-data-1.6RC1.tar.gz
>> http://download.osgeo.org/proj/proj-data-1.6RC1.zip
>> The PROJ release includes a number of bug fixes and updates to the transformation database
>> (see details below). The data package is extended with grids and tinshift files for Norwegian
>> transformations and the Swiss CHGeo2004 geoid model.
>> Please test the release candidates and report your findings back to the mailing list.
>> /Kristian
>> 8.0.1 Release Notes
>> Updates
>> o Database: update to EPSG v10.018 (#2636)
>> o Add transformations for CHGeo2004, Swiss geoid model (#2604)
>> o Additions to the norwegian NKG2020 transformation (#2600)
>> Bug fixes
>> o pj_vlog(): fix buffer overflow in case of super lengthy error message (#2693)
>> o Revert "proj_create_crs_to_crs_from_pj(): do not use PROJ_SPATIAL_CRITERION_PARTIAL_INTERSECTION if area is specified" (#2679)
>> o UTM: error out when value of +zone= is not an integer (#2672)
>> o getCRSInfoList(): make result order deterministic (by increasing auth_name,
>>    code) (#2661)
>> o createOperation(): make sure no to discard deprecated operations if the
>>    replacement uses an unknow grid (#2623)
>> o Fix build on Solaris 11.4 (#2621)
>> o Add mapping of ESRI Equal_Area projection method to EPSG (#2612)
>> o Fix incorrect EPGS extent code for EPSG:7789>EPSG:4976 NKG transformation (#2599)
>> o fix wrong capitalization of CHENyx06_ETRS.gsb (#2597)
>> o createOperations(): improve handling of vertical transforms when
>>    when compound CRSs are used (#2592)
>> o CRS::promoteTo3D(): propagate the extent from the 2D CRS (#2589)
>> o createFromCRSCodesWithIntermediates(): improve performance when there is
>>    no match (#2583)
>> o Fix proj_clone() to work on 'meta' coordinate operation PJ* objects that
>>    can be returned by proj_create_crs_to_crs() (#2582)
>> o add PROJ_COMPUTE_VERSION, PROJ_VERSION_NUMBER,
>>    PROJ_AT_LEAST_VERSION macros (#2581)
>> o Make proj_lp_dist() and proj_geod() work on a PJ* CRS object (#2570)
>> o Fix gcc 11 -Wnonnull compilation warnings (#2559)
>> o Fix use of uninitialized memory in gie tests (#2558)
>> o createOperations(): fix incorrect height transformation between 3D promoted RGF93 and CH1903+ (#2555)
>> PROJ mailing list
>> PROJ at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/proj
> PROJ mailing list
http://www.spatialys.com
More information about the PROJ mailing list
