[PROJ] PROJ 8.0.1RC1 and PROJ-data 1.6RC1
Kristian Evers kristianevers at gmail.com
Wed May 5 01:37:10 PDT 2021
Motion passed with +1’s from
Kristian
Even
Charles
Howard
Thomas
The release will be announced later this afternoon.
/Kristian
> On 4 May 2021, at 22:43, Thomas Knudsen <knudsen.thomas at gmail.com> wrote:
> +1  Thomas
> man. 3. maj 2021 19.36 skrev Kristian Evers <kristianevers at gmail.com <mailto:kristianevers at gmail.com>>:
> Apart from a little mishap with the initial upload of the PROJ files no issues
> with the two release candidates has been reported, so I hereby motion that
> they be promoted to their final versions.
> I’ll start with my +1
> /Kristian
> > On 28 Apr 2021, at 12:49, Kristian Evers <kristianevers at gmail.com <mailto:kristianevers at gmail.com>> wrote:
> > All,
> > I have prepared candidates for the upcoming PROJ 8.0.1 and PROJ-data 1.6 releases.
> > The packages are available from
> > http://download.osgeo.org/proj/proj-8.0.1RC1.tar.gz <http://download.osgeo.org/proj/proj-8.0.1RC1.tar.gz>
> > http://download.osgeo.org/proj/proj-8.0.1RC1.zip <http://download.osgeo.org/proj/proj-8.0.1RC1.zip> and
> > http://download.osgeo.org/proj/proj-data-1.6RC1.tar.gz <http://download.osgeo.org/proj/proj-data-1.6RC1.tar.gz>
> > http://download.osgeo.org/proj/proj-data-1.6RC1.zip <http://download.osgeo.org/proj/proj-data-1.6RC1.zip>
> > The PROJ release includes a number of bug fixes and updates to the transformation database
> > (see details below). The data package is extended with grids and tinshift files for Norwegian
> > transformations and the Swiss CHGeo2004 geoid model.
> > Please test the release candidates and report your findings back to the mailing list.
> > /Kristian
> > 8.0.1 Release Notes
> > Updates
> > o Database: update to EPSG v10.018 (#2636)
> > o Add transformations for CHGeo2004, Swiss geoid model (#2604)
> > o Additions to the norwegian NKG2020 transformation (#2600)
> > Bug fixes
> > o pj_vlog(): fix buffer overflow in case of super lengthy error message (#2693)
> > o Revert "proj_create_crs_to_crs_from_pj(): do not use PROJ_SPATIAL_CRITERION_PARTIAL_INTERSECTION if area is specified" (#2679)
> > o UTM: error out when value of +zone= is not an integer (#2672)
> > o getCRSInfoList(): make result order deterministic (by increasing auth_name,
> >   code) (#2661)
> > o createOperation(): make sure no to discard deprecated operations if the
> >   replacement uses an unknow grid (#2623)
> > o Fix build on Solaris 11.4 (#2621)
> > o Add mapping of ESRI Equal_Area projection method to EPSG (#2612)
> > o Fix incorrect EPGS extent code for EPSG:7789>EPSG:4976 NKG transformation (#2599)
> > o fix wrong capitalization of CHENyx06_ETRS.gsb (#2597)
> > o createOperations(): improve handling of vertical transforms when
> >   when compound CRSs are used (#2592)
> > o CRS::promoteTo3D(): propagate the extent from the 2D CRS (#2589)
> > o createFromCRSCodesWithIntermediates(): improve performance when there is
> >   no match (#2583)
> > o Fix proj_clone() to work on 'meta' coordinate operation PJ* objects that
> >   can be returned by proj_create_crs_to_crs() (#2582)
> > o add PROJ_COMPUTE_VERSION, PROJ_VERSION_NUMBER,
> >   PROJ_AT_LEAST_VERSION macros (#2581)
> > o Make proj_lp_dist() and proj_geod() work on a PJ* CRS object (#2570)
> > o Fix gcc 11 -Wnonnull compilation warnings (#2559)
> > o Fix use of uninitialized memory in gie tests (#2558)
> > o createOperations(): fix incorrect height transformation between 3D promoted RGF93 and CH1903+ (#2555)
> > PROJ mailing list
> > PROJ at lists.osgeo.org <mailto:PROJ at lists.osgeo.org>
> > https://lists.osgeo.org/mailman/listinfo/proj <https://lists.osgeo.org/mailman/listinfo/proj>
> PROJ mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20210505/ee23f840/attachment.html>
More information about the PROJ mailing list
