[PROJ] Geodesic buffers/offsets?
Dave Knopp dave at stellacore.com
Wed May 5 09:00:47 PDT 2021
Nyall Dawson nyall.dawson at gmail.com
Tue May 4 15:23:09 PDT 2021
> Something which I get asked on a recurring basis by users is how to
> create geometry buffers using a real-world distance on a geographic
> dataset. E.g. creating a 100km buffer on a linestring in such a way
> that the geodesic distances between the buffer and original line are
> always 100km.
Assuming there is some desired 'target resolution' associated with the
application (e.g. display pixel sizes, vector polyline sampling
interval, etc.) then perhaps a simple dilation algorithm might work for you.
E.g.
Allocate a working grid associated entire range of lon/lat values at the
resolution you want. Us full ellipsoid range or restrict range of values
if that's appropriate for application cases. With each cell, associate
data structure comprising a scalar and 3D vector.
Initialize the vector portion of the grid cells with corresponding ECEF
locations for relevant surface - e.g. on the ellipsoid, on terrain,
etc). Fill the scalar portion with NaN or whatever.
During iterations, the scalar will be set to the distance metric from
the source points (e.g. distance along geodesic, distance over
undulating terrain surface, etc).
Use lon/lat of source points to find associated grid cell then fill the
scalar part of those grid cells (e.g. using line drawing or other
interpolation if needed). For these cells, set the scalar distance to 0.
Perform a modified 'dilation' algorithm that iterates over cells just
set in last iteration and determine/sets scalar value on unset adjacent
cells.
Assign the new scalar values based on the magnitude of *vector*
difference between cell vector location values. For potential
collisions, use 'shortest wins' strategy.
Iterate on this until grid is full - or optionally stop if all new
distances in iteration exceed the target 'max dist' value.
For vector representation of the buffer boundary, run a contour
following algorithm on the grid scalar values.
That's all off-the-cuff, so maybe not complete nor error free.
Before thinking this is "too much computation" consider the underlying
complexity of other algorithms - which is also high (at comparable
detail). Also this has considerable additional flexibility which might
boost reuse potential.
Dave
More information about the PROJ mailing list
