[PROJ] Transformation from WKT string?
Even Rouault even.rouault at spatialys.com
Fri May 28 15:13:02 PDT 2021
Daniel,
It is likely one of the ESRI specific things at
https://raw.githubusercontent.com/Esri/projection-engine-db-doc/master/csv/pe_list_geogtran.csv
The situation is that the import script of the ESRI database does import
them in the PROJ database with some ad-hoc logic, but proj_create() has
no support for those strings themselves. However, as they are in the
database, you can use them by name (provided yours is a registered one,
and not a custom one), with proj_create_from_name() (or if you find its
code in the above list, with proj_create_from_database())
e.g.
projinfo -k operation Palestine_1923_To_WGS_1984_1X
PROJ string:
+proj=pipeline
   +step +proj=axisswap +order=2,1
   +step +proj=unitconvert +xy_in=deg +xy_out=rad
   +step +inv +proj=longlat +a=6378300.789 +b=6356566.435
   +step +proj=push +v_3
   +step +proj=cart +a=6378300.789 +b=6356566.435
   +step +proj=helmert +x=-181 +y=-122 +z=225
   +step +inv +proj=cart +ellps=WGS84
   +step +proj=pop +v_3
   +step +proj=unitconvert +xy_in=rad +xy_out=deg
WKT2:2019 string:
COORDINATEOPERATION["Palestine_1923_To_WGS_1984_1X",
     SOURCECRS[
         GEOGCRS["Palestine 1923",
             DATUM["Palestine 1923",
                 ELLIPSOID["Clarke 1880
(Benoit)",6378300.789,293.466315538981,
                     LENGTHUNIT["metre",1]]],
             PRIMEM["Greenwich",0,
                 ANGLEUNIT["degree",0.0174532925199433]],
             CS[ellipsoidal,2],
                 AXIS["geodetic latitude (Lat)",north,
                     ORDER[1],
                 AXIS["geodetic longitude (Lon)",east,
                     ORDER[2],
             ID["EPSG",4281]]],
     TARGETCRS[
         GEOGCRS["WGS 84",
             ENSEMBLE["World Geodetic System 1984 ensemble",
                 MEMBER["World Geodetic System 1984 (Transit)"],
                 MEMBER["World Geodetic System 1984 (G730)"],
                 MEMBER["World Geodetic System 1984 (G873)"],
                 MEMBER["World Geodetic System 1984 (G1150)"],
                 MEMBER["World Geodetic System 1984 (G1674)"],
                 MEMBER["World Geodetic System 1984 (G1762)"],
                 ELLIPSOID["WGS 84",6378137,298.257223563,
                     LENGTHUNIT["metre",1]],
                 ENSEMBLEACCURACY[2.0]],
             CS[ellipsoidal,2],
                     ORDER[1],
                     ORDER[2],
             ID["EPSG",4326]]],
     METHOD["Geocentric translations (geog2D domain)",
         ID["EPSG",9603]],
     PARAMETER["X-axis translation",-181,
         LENGTHUNIT["metre",1],
         ID["EPSG",8605]],
     PARAMETER["Y-axis translation",-122,
         ID["EPSG",8606]],
     PARAMETER["Z-axis translation",225,
         ID["EPSG",8607]],
     OPERATIONACCURACY[1.5],
     USAGE[
         SCOPE["Not known."],
         AREA["Israel - onshore and offshore."],
         BBOX[29.45,32.99,33.53,35.69]],
     ID["ESRI",108220]]
If it is a custom one, the logic at
https://github.com/OSGeo/PROJ/blob/master/scripts/build_db_from_esri.py#L1480
might help
Even
Le 29/05/2021 à 00:00, Daniel Schilling a écrit :
> Greetings!
> I am trying to create a bound CRS using `proj_crs_create_bound_crs`,
> but I only have a WKT string (`GEOGTRAN`...) for the transformation,
> not an EPSG code.  I cannot figure out how to do it.
> Neither `proj_create` nor `proj_create_from_wkt` seem able to create
> transformations. The only way I have been able to create a
> transformation so far is by using `proj_create_from_database`, but
> again - I don't have an EPSG code for this.  Is there a way to do
> this?  I am using Proj 8.
> Thank you in advance for your help!
> Daniel Schilling
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20210529/000ea570/attachment.html>
More information about the PROJ mailing list
