[PROJ] Am I supposed to get same results with libproj if passing proj4 +proj from/to crs ?
Even Rouault
even.rouault at spatialys.com
Wed Nov 10 12:45:07 PST 2021
> The question is should PROJ default to PROJ_NETWORK=ON if the
> PROJ_NETWORK configuration or environment variable is not defined? The
> current behaviour is that it defaults to OFF behavior.
When https://proj.org/community/rfc/rfc-4.html was discussed, a few
people were against automatic network access, hence this default.
The default can also be changed by tuning proj.ini:
https://proj.org/resource_files.html#proj-ini
http://www.spatialys.com
More information about the PROJ
