[PROJ] Strange axes in LV03
Javier Jimenez Shaw j1 at jimenezshaw.com
Fri Oct 8 03:29:42 PDT 2021
Hi
Reading the axes of EPSG:21781 https://epsg.org/crs_21781/CH1903-LV03.html
(Switzerland) I found something strange:
    CS[Cartesian,2],
        AXIS["easting (Y)",east,
            ORDER[1],
            LENGTHUNIT["metre",1]],
        AXIS["northing (X)",north,
            ORDER[2],
The first axis is east... however the abbreviation is "Y". Is there any
reason for that? Is it just a mistake in EPSG data? I have the impression
that I should ignore that abbreviation, and relay only on the direction.
But it is getting hard ;)
Thanks.
.___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20211008/65e23afc/attachment.html>
More information about the PROJ mailing list
