[PROJ] promoteTo3D in ftUS
Even Rouault
even.rouault at spatialys.com
Thu Oct 21 12:14:26 PDT 2021
Le 21/10/2021 à 20:53, Javier Jimenez Shaw a écrit :
> Hi
> There is currently a method
> CRSNNPtr CRS::promoteTo3D(const std::string &newName,
> const io::DatabaseContextPtr &dbContext) const
> that adds vertical axis in Meters (if there is no one there, etc).
> Sometimes (when working with CRS from USA), I need the vertical one in
> ft or ftUS.
promoteTo3D() will create a Geographic3D CRS or a Projected 3D CRS, ie
with ellipsoidal heights, not orthometric height. Are ellipsoidal
heights in ft/ftUS really what you need ?
> There is another function
> const io::DatabaseContextPtr &dbContext,
> const cs::CoordinateSystemAxisNNPtr
> &verticalAxisIfNotAlreadyPresent) const
> but it is "PROJ_INTERNAL" (whatever it means)
Just that it restricts a method from being exported in a class that is
exported. I tend to be conservative of what I expose in the API if I'm
not sure it will be needed by external users.
> Would it make sense to have a function (or overload) that specifies
> the unit?
If that's the function you need, just removing PROJ_INTERNAL, moving it
in the public part and adding doc should be enough.
The CRS::alterCSLinearUnit() method could also be useful.
> Thanks.
> .___ ._ ..._ .. . ._. .___ .. __ . _. . __.. ... .... ._ .__
> Entre dos pensamientos racionales
> hay infinitos pensamientos irracionales.
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20211021/35febe17/attachment.html>
More information about the PROJ
