[PROJ] Behavior of proj_create_crs_to_crs() when using +proj=utm format
Even Rouault
even.rouault at spatialys.com
Tue Oct 26 10:01:29 PDT 2021
> Thanks for your complete answer, Even. Only for curiosity (and without
> any criticism), why PROJ moved part of the code from the beautiful and
> practical C language to the ugly C++?
You're coming late to the party. That was discussed in the thread at
https://lists.osgeo.org/pipermail/proj/2018-May/007799.html
yep C++ can be ugly, but good luck with memory management if you want to
implement ISO:19111 in C. Oh well, you could certainly do that, but it
would be extremely verbose and error prone.
| I hope at least the C interface will be forever maintained.
Yes, as long as C remains something available and used.
http://www.spatialys.com
More information about the PROJ
