[PROJ] PROJ 8.1.1
Kristian Evers kristianevers at gmail.com
Wed Sep 1 11:29:49 PDT 2021
On behalf of the PROJ development team I am happy to announce the
release of PROJ 8.1.1
Download the archives here:
http://download.osgeo.org/proj/proj-8.1.1.tar.gz <http://download.osgeo.org/proj/proj-8.1.1.tar.gz>
http://download.osgeo.org/proj/proj-8.1.1.zip <http://download.osgeo.org/proj/proj-8.1.1.zip>
The PROJ release includes a number of bug fixes and updates to the
transformation database (see details below).
/Kristian
8.1.1 Release Notes
 Updates
 o EPSG Database updated to version 10.028 (#2773)
 Bug Fixes
 o Include algorithm header file to avoid build errors on Alpine Linux (#2769)
 o CMake: fix installation of executables on iOS (#2766)
 o Associate extents to transformations of CRS's that include GEOIDMODEL (#2769)
 o Logging: avoid some overhead when logging is not enabled (#2775)
 o ortho: remove useless and invalid log trace (#2777)
 o CMake: remove external nlohmann_json from INTERFACE_LINK_LIBRARIES target (#2781)
 o createOperations(): fix SourceTargetCRSExtentUse::NONE mode (#2783)
 o GeoTIFF grid reading: perf improvements (#2788)
 o Conversion::createUTM(): avoid integer overflow (#2796)
 o Inverse laea ellipsoidal: return PROJ_ERR_COORD_TRANSFM_OUTSIDE_PROJECTION_DOMAIN
   when appropriates (#2801)
 o Make sure that proj_crs_promote_to_3D returns a derived CRS (#2806)
 o createOperations(): fix missing deg<-->rad conversion when transforming with a
   CRS that has a fallback-to-PROJ4-string behaviour and is a BoundCRS of a
   GeographicCRS (#2808)
 o WKT2 import/export: preserve PROJ.4 CRS extension string in REMARKS[] (#2812)
 o BoundCRS: accept importing/exporting in WKT2 and PROJJSON the
   scope/area/extent/id attributes (#2815)
 o ConcatenatedOperation::fixStepsDirection(): fix bad chaining of steps when
   inverse map projection is involved in non-final step (#2819)
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20210901/f48ac0c5/attachment.html>
More information about the PROJ mailing list
