[PROJ] Migrating to proj API 6+ without forcing crs input
Even Rouault even.rouault at spatialys.com
Thu Apr 14 08:41:05 PDT 2022
I already answered (I admit I more and more terse with years) in
https://github.com/OSGeo/PROJ/issues/3161#issuecomment-1094238124
So for your case where you don't have a CRS but a pipeline, and assuming
it serves the role of the source, you'd need an alternate code path that
would do
PJ* P = proj_create(ctxt, "+proj=pipeline " +
your_pipeline_without_proj_equal_pipeline_and_with_steps_in_reverse_order_and_with_+inv_qualifier_added_when_absent_or_removed_when_present
+ " +step " + proj_string_of_target )
proj_trans(P, PJ_FWD, ...);
so yes, there's a bunch of PROJ string manipulation to do.
Even
Le 14/04/2022 à 17:16, Johannes Schauer Marin Rodrigues a écrit :
> Dear proj list,
> in my application [1] I was using the ability of the Python mapnik library to
> render an arbitrary transformation by supplying my own custom proj string (a
> +proj=pipeline with +proj=tinshift). This stopped working when mapnik
> implemented support for the proj API 6+ [2] because mapnik followed the proj
> migration guide and turned code that looked like this before:
>      projPJ pj_longlat = pj_init_plus(source);
>      projPJ pj_merc = pj_init_plus(target);
>      pj_transform(pj_longlat, pj_merc, ...)
> Into code that looks like this:
>      PJ *P = proj_create_crs_to_crs(PJ_DEFAULT_CTX, source, target, NULL);
> This means that in contrast to before, the source and target transformation
> must now be a CRS. My own custom proj string (a pipeline) is not a CRS and thus
> my code is now non-functional with mapnik versions from git.
> I want to contribute an alternative codepath to mapnik which restores its
> previous ability to work with arbitrary proj strings (even those that are not a
> CRS). But how is this done? All projects that migrated to API 6+ that I was
> able to find follow the migration guide and call proj_create_crs_to_crs.
> So my question ultimately becomes: how do I implement proj API 6+ support
> without proj_create_crs_to_crs so that the software retains its ability to
> handle arbitrary user-supplied proj strings?
> I also asked the same question on stackoverflow [3] in case somebody wants to
> grab the bounty.
> Thanks!
> cheers, josch
> [1] https://blog.mister-muffin.de/2014/04/03/mapbender---maps-for-long-distance-travels/
> [2] https://github.com/mapnik/mapnik/commit/88241b32eeaccdc9eda7b92b7e7b6d4deac88e12
> [3] https://stackoverflow.com/questions/71823105/migrating-to-proj-api-6-without-forcing-crs-input
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
More information about the PROJ mailing list
