[PROJ] Correcting metadata in GeoTIFF files
Even Rouault even.rouault at spatialys.com
Tue Feb 8 06:05:17 PST 2022
Jochem,
> Since GeoTIFF grids are not supported in PROJ <6 and the
> naptrans2008/2018 grids of the Netherlands are only needed with the
> PROJ <6 behaviour, there is no need for naptrans2008.tif or
> naptrans2018.tif. Could I ask to remove nl_nsgi_naptrans2018.tif (and
> naptrans2018.tif, if present) from PROJ (and keep the .gtx versions,
> if present in PROJ)?
Fine for me.
> Can I do this with the same pull request as replacing some other
> GeoTIFF grid files for the Netherlands to correct metadata?
Sounds ok. See
https://github.com/OSGeo/PROJ-data/blob/master/CONTRIBUTING.md#how-to-remove-a-file
(the next version of PROJ-data will be 1.9)
> I think it would be a good idea to change the way a interpolation CRS
> should be specified in a Geodetic TIFF Grid. The only mentioned
> example of this was naptrans2008 and this grid is no longer needed, so
> this change seems not very urgent if naptrans2008.tif and
> naptrans2018.tif grids are removed. However, we should at least edit
> the documentation so it no longer mentions naptrans2008 as example in:
> https://proj.org/specifications/geodetictiffgrids.html
Perhaps just change the "is" to "was" in the sentence starting with "The
only instance we have in mind is ..."
Even
> Regards, Jochem
> Disclaimer:
> De inhoud van deze e-mail is vertrouwelijk en uitsluitend bestemd voor
> de geadresseerde(n).
> Gebruik, openbaarmaking, vermenigvuldiging, verspreiding en/of
> verstrekking van deze informatie aan derden is niet toegestaan.
> Op al onze producten en diensten zijn onze algemene
> leveringsvoorwaarden van toepassing
> [https://www.kadaster.nl/algemene-leveringsvoorwaarden].
> Disclaimer:
> This email and any files transmitted with it are confidential and
> intended solely for the use of the individual or entity to whom they
> are addressed.
> If you are not the intended recipient, you are notified that
> disclosing, copying, distributing or taking any action in reliance on
> the contents of this information is strictly prohibited.
> Our general terms and conditions of delivery apply to all our products
> and services
> [https://www.kadaster.com/general-terms-and-conditions].
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20220208/41dce62e/attachment.html>
More information about the PROJ mailing list
