[PROJ] PROJ 9.0.0RC1 & PROJ-data 1.9RC1
Even Rouault
even.rouault at spatialys.com
Tue Feb 15 13:42:48 PST 2022
Kristian,
technically as we didn't break any API or ABI compared to 8.2.1, I
believe we could have treated that as a feature release w.r.t libtool
like version numbers, hence with:
set(PROJ_LIBTOOL_CURRENT 25)
set(PROJ_LIBTOOL_REVISION 0)
set(PROJ_LIBTOOL_AGE 3)
keeping the same SONAME at 25 -3 = 22
(if we exclude the removal of autoconf, this is closer to being a 8.3.0
than a 9.0.0)
But I don't have a strong enough opinion w.r.t to the above to know if
it's worth a RC2
Otherwise it builds fine here
Even
Le 15/02/2022 à 21:23, Kristian Evers a écrit :
> All,
> I have just uploaded releases candiates for the upcoming releases of PROJ 9.0.0 and PROJ-data 1.9.
> The PROJ release candidate is includes various improvements, a few bug fixes and most notably
> it *doesn’t* include autotools makefiles. See the draft release notes below.
> The PROJ-data packages includes new grids for the Polish ETRF2000-PL, Norwegian chart datum grids
> and the Belgian hBG18 geoid model.
> Download the two release candidates here:
> https://download.osgeo.org/proj/proj-9.0.0RC1.tar.gz
> https://download.osgeo.org/proj/proj-9.0.0RC1.zip
> https://download.osgeo.org/proj/proj-data-1.9RC1.tar.gz
> https://download.osgeo.org/proj/proj-data-1.9RC1.zip
> As usual everyone who uses PROJ is encouraged to try out the release candidates and report
> back their experiences either here on the mailing list or in the issue tracker on GitHub.
> /Kristian
> 9.0.0 Release Notes
> Breaking Changes
> o Support for the autotools build system has been removed (#3027)
> See RFC7 for details: https://proj.org/community/rfc/rfc-7.html
> Updates
> o Database updates:
> + ESRI projection engine db to version 12.9 (#2943)
> + EPSG v10.054 (#3051)
> + Vertical grid files for PL-geoid-2011, Polish geoid model (#2960)
> + Belgian geoid model hBG18 to grid alternatives (#3044)
> o Add new option to proj_create_crs_to_crs_from_pj method to force +over on
> transformation operations (#2914)
> o Specify CMAKE_INSTALL_RPATH for macOS; use -rpath LDFLAGS for tests (#3009)
> o Implement Geographic3D to Depth/Geog2D+Depth as used by ETRS89 to CD Norway
> depth (#3010)
> o Allow PROJ_LIB paths wrapped with double quotes (#3031)
> o Use external gtest by default when possible (#3035)
> o CMake: make BUILD_SHARED_LIBS=ON the default even on Windows (#3042)
> o proj.ini: add a 'ca_bundle_path' variable (#3049)
> Bug fixes
> o Fix extremely long parsing time on hostile PROJ strings (#2968)
> o CMake: fix warning with external googletest (#2980)
> o proj_get_crs_info_list_from_database(): report PJ_TYPE_GEODETIC_CRS for
> IAU_2015 -ocentric geodetic CRS (#3013)
> o peirce_q: rename +type parameter wrongly introduced in 8.2.1 to +shape (#3014)
> o Set more precise error code for parsing errors in proj_create() (#3037)
> o createOperations(): fix transformations from/to a BoundCRS of a
> DerivedGeographicCRS coming from WKT (#3046)
> o Better deal with importing strings like '+init=epsg:XXXX +over' (#3055)
> o Fix importing CRS definition with +proj=peirce_q and +shape different from
> square or diamond (#3057)
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
More information about the PROJ
