[PROJ] OGRCreateCoordinateTransformation()
Even Rouault even.rouault at spatialys.com
Thu Mar 24 10:54:44 PDT 2022
Le 24/03/2022 à 18:36, Erixen Cruz a écrit :
>>     PROJ4_GRIDS provided a way to specify exactly which geoid file(s)
>>     to use.  Some vertical datums, such as NAVD88, only have a single
>>     EPSG code for multiple geoids – what’s the replacement for
>>     PROJ4_GRIDS in PROJ9?  If I could switch to WKT2 strings (not
>>     sure that’s really feasible) does it fix these problems?
>      WKT2 hardly helps for that.
> There is one way to get WKT2 to do just this. Here's the start of the
> thread about that:
> https://lists.osgeo.org/pipermail/proj/2019-December/009142.html. TLDR
> you use a BOUNDCRS with an ABRIDGEDTRANSFORMATION. Thanks again, Even,
> for pointing us in this direction.
> This is not ideal though. Like Even said, this (mis)use of BOUNDCRS
> doesn't fit very cleanly in PROJ9 at the moment.
yeah, that can be used in PROJ (and that's exactly how a WKT1 with a
TOWGS84 or PROJ4_GRIDS, or a PROJ.4 strings with
+towgs84/+nadgrids/+geoidgrids end up being represented), but
pedantically a BOUNDCRS[] is not a CRS. PROJ does accept is as a CRS
(such as a COMPOUNDCRS of BOUNDCRS[]) because there was no other
convenient way of modeling those legacy features in ISO19111:2019 /
WKT2:2019, but this is an extension, and strictly conforming other
implementations would reject that.
And the ABRIDGEDTRANSFORMATION[]  syntax cannot be used for vertical
transformations where the geographic CRS would not be the interpolation CRS.
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20220324/b08cef76/attachment.html>
More information about the PROJ mailing list
