[PROJ] GPS to MSL
Even Rouault
even.rouault at spatialys.com
Wed Sep 28 03:03:46 PDT 2022
Paul,
Great post.
I've noticed you point to the https://www.agisoft.com/downloads/geoids/
page which mentions they use the PROJ GTG format. A lot of their files
have the same names as the ones provided by https://cdn.proj.org/ , but
they are not exactly the same... Looking at au_ga_AUSGeoid98.tif, it
appears they have reprocessed them to modify the TIFFTAG_COPYRIGHT
(removing the license information) and TIFFTAG_IMAGEDESCRIPTION. Also
adding the nodata value tag (PROJ grids only contain it when they are
actual grid values at the nodata value). And more annoying they have
also modified the GDAL_METADATA tag in a way it is not currently
understood by current GDAL versions (adding the <?xml version="1.0"
encoding="UTF-8"?> marker before the root <GDALMetadata> element,
whereas GDAL expects the string to start directly with <GDALMetadata>),
so the GTG specific metadata is hidden. I'm going to fix the GDAL
GeoTIFF reader to be more robust to that.
I've also noticed that the dk_sdfe_dvr90.tif file they provide is quite
different from the PROJ CDN: it has not the same extent and spatial
resolution.
A bit annoying to reuse the same file names as the ones we provide but
with different content.
Anyway this is rather for any Agisoft employee reading this email....
Even
Le 28/09/2022 à 10:06, Paul Harwood a écrit :
> This is not a question but a request.
> I had to work out an API to convert from GPS coordinates to Height
> above MSL. Having made it work, I wrote a blog post about the
> solution, since I like to document things. I have posted it here for
> three reasons :
> 1 As a thank you to the team. The simplicity of the actual solution
> shows just how good PROJ is!
> 2 In case you want a good laugh, and
> 3 more seriously, given the impressive competence on this list, I
> would like to know if I have made any glaring (or even subtle) mistakes.
> Thank you
> https://medium.com/p/70b723767787
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
More information about the PROJ
