[PROJ] ISEA projection: proposed parameters deprecation and input latitude interpretation
Luís Moreira de Sousa
luis.de.sousa at protonmail.ch
Tue Aug 27 03:28:06 PDT 2024
Hi again Jérôme, your reasoning is solid. I see now that extra parameter is not really necessary.
Regards.
Mastodon: https://mastodon.social/@luis_de_sousa
URL: https://ldesousa.codeberg.page
Sent with [Proton Mail](https://proton.me/) secure email.
On Tuesday, 27 August 2024 at 10:47, Jérôme St-Louis <jerome at ecere.com> wrote:
> Hi Luís,
> Thanks for the input.
>> adding azi= instead.
> To be clear, the +azi= parameter is already there for the forward projection, just not in the new inverse yet.
>> I wonder whether the angular coordinates interpretation shouldn't also be left to the user to decide. Eventually with the authalic transformation as default behaviour.
> Do you mean by introducing an additional parameter? I don't think this should be necessary, and I think it would go against how ellipsoids are generally handled for all projections in PROJ.
> If using a perfectly spherical ellipsoid, all types of latitudes are the same.
> The bold title I used for that section of my last e-mail was confusing, sorry.
> What I meant is that if an oblate spheroid ellipsoid is used (which is the default if you don't specify any ellipsoid parameter e.g., simply saying +proj=isea), then the latitude should be interpreted as geodetic latitude, but it should be transformed to an authalic latitude prior to applying the ISEA projection which is only defined on a sphere, just like it is already being done for Lambert Azimuthal Equal-Area. This is the only correct thing to do I believe.
> Some systems do, arguably incorrectly, take the geodetic latitude, and directly apply the ISEA spherical projection pretending that latitude is already the authatlic latitude on the sphere.
> This could still be done with PROJ simply by specifying +R=6371007.18091875, and still giving the same geodetic latitude as input.
> Other systems (still arguably incorrectly, like ours currently) convert the geodetic latitude to geocentric latitude before applying the ISEA projection.
> This could still be achieved by specifying +proj=pipeline +step +proj=geoc +step +proj=isea +R=6371007.18091875
> Therefore I think even these incorrect interpretations could still be explicitly specified by the user, using the non-projection-specific PROJ mechanisms, without the introduction of a projection-specific parameter.
> But the default when using a non-spherical ellipsoid would be the correct way of first transforming geoetic latitude to authalic latitude.
> I hope that makes sense.
> Kind regards,
> -Jerome
> On 8/27/24 5:20 AM, Luí s Moreira de Sousa wrote:
>> Hi Jérôme,
>> this is all very logical, dropping those DGGS paramaters and adding azi= instead.
>> Regards.
>> On Saturday, 24 August 2024 at 15:36, Jérôme St-Louis via PROJ [<proj at lists.osgeo.org>](mailto:proj at lists.osgeo.org) wrote:
>>> Dear PROJ community,
>>> I recently had the chance to integrate an implementation of the inverse transformation for the [Icosahedral Snyder Equal-Area (ISEA) projection](https://proj.org/en/9.4/operations/projections/isea.html) ([PR #4211](https://github.com/OSGeo/PROJ/pull/4211) which was recently merged).
>>> Doing so resulted in some initial re-factoring to share code between the forward and inverse projection.
>>> Deprecating grid parameters
>>> During this process, I realized that several parameters for the projection (+proj=isea) really have nothing to do with the projection itself, but are parameters for constructing discrete global grids on top of an ISEA projection.
>>> In fact, [the code applying these parameters](https://github.com/OSGeo/PROJ/blob/master/src/projections/isea.cpp#L931) happens as a later step after the default planar projection (with the exception of the trivial [isea_tri_plane()](https://github.com/OSGeo/PROJ/blob/master/src/projections/isea.cpp#L656)).
>>> Therefore, I suggest this code really does not belong in the PROJ library, but outside, in the implementation of a discrete global grid system, such as in libraries like [DGGRID](https://github.com/sahrk/DGGRID) and [geogrid](https://github.com/mocnik-science/geogrid/), and these parameters should be deprecated.
>>> In addition:
>>> - there is no documentation at all for the parameters and they are very poorly understood,
>>> - there are no existing tests for these parameters,
>>> - the new inverse transformation does not support these parameters.
>>> The three parameters proposed for deprecation are:
>>> +mode which can be set to plane (the default), di, dd, or hex
>>> The default mode is plane which would become the only thing supported.
>>> hex referred to returning coordinates related to a hexagonal grid, but it is really not clear.
>>> di and dd seemed to refer to a rhombus grid, in a way very similar to the approach we use for an [ISEA9R DGGRS](https://docs.ogc.org/DRAFTS/21-038.html#isea9r-dggrs) (or ISEA4R for a quad-tree).
>>> The ISEA planar projection can be very easily transformed to a space where icosahedron triangles merge into 10 axis-aligned rhombuses by applying a 60 degrees rotation and 30 degrees horizontal shearing, which can be done with +proj=affine.
>>> This seems to be what [isea_ptdd()](https://github.com/OSGeo/PROJ/blob/master/src/projections/isea.cpp#L669) is doing for dd.
>>> di seems to be referring to an extra step done in [isea_ptdi()](https://github.com/OSGeo/PROJ/blob/master/src/projections/isea.cpp#L849). I have no idea what this is doing.
>>> +aperture which is the aperture (refinement ratio) of the discrete global grid for those di, dd and hex modes
>>> +resolution which I am not sure how it affects the di, dd, and hex modes, but is only used with those modes proposed for deprecation
>>> Systems using these parameters could still extract the code for these extra steps in its [current state](https://github.com/OSGeo/PROJ/blob/2ce6c7a9b1ca44b8a7cfb1acca7ff10c8c616774/src/projections/isea.cpp), and invoke as an extra step after the planar projection (after undoing the trivial 180 deg rotation and translation that [isea_tri_plane()](https://github.com/OSGeo/PROJ/blob/master/src/projections/isea.cpp#L656) is doing).
>>> If you make use of these parameters and object to their deprecation, please reply with feedback.
>>> I plan to submit a pull request for a staged deprecation, which first mentions in the documentation that these parameters will be deprecated in a future version.
>>> On the flip side, I hope to eventually contribute support for the remaining +azi= parameter not yet supported by the inverse projection (which allows support for orientations such as the R. Buckminster Fuller's Dymaxion Orientation).
>>> Possibly also eventually allowing to specify an arbitrary latitude and longitude for the first icosahedron vertex, as opposed to the two available options of +orient=pole and +orient=isea with fixed values.
>>> Proposing to interpret input latitude as authalic latitude
>>> As [discussed in the PR](https://github.com/OSGeo/PROJ/pull/4211#issuecomment-2275206640), the ISEA projection is only defined on a sphere.
>>> Although I clarified this in the [documentation](https://osgeo-proj--4211.org.readthedocs.build/en/4211/operations/projections/isea.html), the most common use case is having geodetic WGS84 latitude and longitude coordinates which you want to project to the ISEA planar projection.
>>> This includes the use case of integrating data into a discrete global grid system using a DGGRS based on the ISEA projection, such as ISEA3H or ISEA9R.
>>> Before applying the spherical projection with a sphere whose surface area is the same as the GRS80 or WGS84 ellipsoid (authalic sphere), the geodetic latitude should be converted to an [authalic latitude](https://en.wikipedia.org/wiki/Latitude#Authalic_latitude).
>>> This is already done by PROJ in other projections, including the Lamber Azimuthal Equal-Area projection of which ISEA is modified form, if I understand correctly (see https://github.com/OSGeo/PROJ/blob/master/src/projections/laea.cpp#L38 and https://github.com/OSGeo/PROJ/pull/4211#issuecomment-2284383509 ).
>>> I propose that the geodetic latitude be automatically converted to an authalic latitude when using the projection with a non-spherical ellipsoid (which is the default, and therefore currently quite prone to misuse).
>>> Please reply if you see any issue with this change, for which I also plan to submit a pull request.
>>> Thank you very much!
>>> Kind regards,
>>> -Jerome
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240827/39967e5c/attachment-0001.htm>
More information about the PROJ
