[PROJ] Transformations in ITRF2020
Even Rouault even.rouault at spatialys.com
Tue Aug 27 10:55:02 PDT 2024
Javier,
I believe that registering a concatenated operation for ITRF2020 ->
ETRS89 = ITF2020->ETRF2020+ETRF2020->ETRS89 in the database should be
enough for PROJ to infer the ITRF2020 -> CH1903+ pipeline
Even
Le 27/08/2024 à 19:29, Javier Jimenez Shaw via PROJ a écrit :
> Hi
> I am now facing transformations with ITRF2020 with time(yes, because
> Skylark, but I guess more NTRIPs are going to do (or already doing)
> the same)
> The point is when the destination CRS does not have a direct
> transformation from ITRF2020 (or almost).
> For instance, EPSG:4150, CH1903+ (the geographic of LV95, in
> Switzerland) is only connected to ETRS89. See that CH1903+ is in the
> European tectonic plate, as ETRS89
> A direct transformation is completely ballpark
> echo 42 6 0 2024.6 | ./cs2cs EPSG:9989 EPSG:4150 -d 9 --3d
> 42.000000000 6.000000000 0.000000000 2024.6
> However, from ITRF2020 to ETRS89 there is some change due to the time
> (the European plate moving at 2.5 cm/a since 2015):
> echo 42 6 0 2024.6 | ./cs2cs EPSG:9989 EPSG:4937 -d 9 --3d
> 41.999994981 5.999991317 -0.001861237 2024.6
> and from ETRS89 to CH1903+ due to the datum offset:
> echo 42 6 0 2024.6 | ./cs2cs EPSG:4937 EPSG:4150 -d 9 --3d
> 42.000742733 6.000670188 -60.682799297 2024.6
> Looking at the pipelines, the steps would be ITRF2020 -> ETRF2020 ->
> ETRS89 -> CH1903+
> (btw, only since PROJ 9.4.1, when ETRF2020 was added)
> I understand that the only way to get the proper transformation is
> chaining these two manually. Via ETRS89 ... because I know it. Right?
> Well, the future does not look so promising to me: in EPSG I only see
> transformations from ITRF2020 to ETRF family, NAD83(2011) family and
> NAD83(CSRS)v8. That is Europe, USA and Canada. That's all, folks.
> Thanks,
> .___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
> Javier Jimenez Shaw
> Mercator str 42.
> Null-Island
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240827/75634f07/attachment.htm>
More information about the PROJ mailing list
