[PROJ] Syntax to change projection from UTM to TM
Javier Jimenez Shaw
j1 at jimenezshaw.com
Fri Dec 6 12:41:09 PST 2024
Why +k=0.9996439573 for UTM?
It should be 0.9996, right?
On Fri, 6 Dec 2024, 21:29 Ulises Ibarra via PROJ, <proj at lists.osgeo.org>
wrote:
> Hello, I would like you to please guide me with my following couple of
> questions:
> I have a list of coordinates in a UTM Zone 14 North projection, in the
> ITRF2008 datum, I would like to change them to a Transverse Mercator
> projection, in which the central meridian lon_0 coincides in longitude with
> one of the points on my list, point 1: UTM(1, East=479969.231,
> North=2143791.499, Elevation=2274.949) and or in geographic coordinates (1,
> lat=19.388187333, lon=-99.190762728, Elevation=2274.949)
> Question: Would it be correct to use the following syntax and parameters?
> Because I am not getting the expected result.:
> echo 480037.249 2143783.696 2271.294 | cct +proj=pipeline +step +inv
> +proj=utm +zone=14 +ellps=GRS80 +k=0.9996439573 +step +proj=tmerc
> +lat_0=19.388187333 +lon_0=-99.190762728 +x_0=479969.231 +y_0=2143791.499
> +ellps=GRS80 +k=1
> I get the output: 480037.2841 2143783.7685 2271.2940 inf
> The correct result should be: 480037.3001 2143783.6901 2271.294
> Best regards
> Ulises
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20241206/3bbec14a/attachment.htm>
More information about the PROJ
