[PROJ] [gdal-dev] LIBERTIFF / Thread-safe TIFF reader
Even Rouault
even.rouault at spatialys.com
Thu Dec 19 09:13:59 PST 2024
> Without thinking too much:
> You say '"port"' (in quotes), and I don't follow. The new
> implementation is a library, even if it does not have a .so. So it
> seems obvious that it would become a dependency of a particular gdal
> driver and, of proj. If that means adding a feature for proj that
> gdal doesn't need, and one codebase, that's fine and the normal
> approach. If you mean "there are two live branches of libertiff",
> that sounds like a bad idea.
No, vendor libertiff.hpp into PROJ as already done in GDAL. If someone
wants to package libertiff as a standalone package, fine for them, but
we're probably not at that point of success that we need to do it. I'm
happy to resync libertiff_upstream/GDAL/PROJ libertiff.hpp when needed.
Given its limited scope, it is probably close to be feature complete.
> This doesn't read all tiff, and proj might be reading grid files that
> the people who made them think are compliant, but that the new lib
> won't read.
Yep, that's the main restriction. So this is a question for the
community: does anyone use PROJ TIFF grids with a codec that is not
uncompressed or deflate ?
> Thus this is really a proposal to do two things:
> - change the specification of proj to read only a limited subset of
> tiff
> - change to a simpler implementation that still meets that new
> specification
> That raises the question of whether the grid file spec is bigger than
> proj, and how such a change would be viewed by others, or if this is
> "there is a spec, but to use it with proj it has to meet narrower
> spec-prime".
Yes the deal would be: you can use any valid (Geo)TIFF/(Geo)BigTIFF
big/little endian ordered, provided you limit yourself to uncompressed
or deflate.
> <dark_humor>Maybe take it to OGC</>
Fortunately, there's nothing geo in this!
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
Mood of the day: "Bien entendu, on peut sauter sur sa chaise comme un cabri en disant : les standards ! les standards ! les standards ! Mais ça n’aboutit à rien et ça ne signifie rien." ~ dixit De Gaulle
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20241219/6e9c890d/attachment.htm>
More information about the PROJ
