[PROJ] Unexpected conversion behaviour.
Even Rouault even.rouault at spatialys.com
Thu Dec 19 16:40:42 PST 2024
Hi Chris,
I see in pj_get_suggested_operation() a  normalizeLongitude() longitude
that renormalize longitudes to [-180,180]. Perhaps this is related to
how you've defined the area of use of your transformation?  It should be
something like
min_lat,longitude_a_bit_below_180,max_lat,longitude_a_bit_above_minus_180
for an area of use intersecting the antimeridian.
Even
Le 20/12/2024 à 01:16, Chris Crook via PROJ a écrit :
> UNCLASSIFIED
> Hi PROJ people
> I am looking at a conversion (EPSG:4176->EPSG:4272) which is
> lat/lon->lat/lon via a distortion grid.  Unexpectedly I get a
> different answer by adding 360 degrees to the input coordinate.
> It looks like this possibility is not accounted for when testing
> whether the grid is applicable, so it falls back to the less accurate
> option.   Is that correct? And if so would it make sense to allow
> longitude wrapping when evaluating conversion options?
> $ test_nzgd1949.sh
> + cs2cs
> Rel. 8.2.1, January 1st, 2022
> usage: cs2cs [-dDeEfIlrstvwW [args]]
>               [[--area name_or_code] | [--bbox
> west_long,south_lat,east_long,north_lat]]
>               [--authority {name}] [--accuracy {accuracy}] [--no-ballpark]
>               [+opt[=arg] ...] [+to +opt[=arg] ...] [file ...]
> + echo -42 173
> + cs2cs EPSG:4167 EPSG:4272 -d 8
> -42.00171693    172.99984072 0.00000000
> + echo -42 -187
> -42.00169999    172.99986158 0.00000000
> Thanks
> *Chris Crook ** (**he/him
> <https://www.publicservice.govt.nz/our-work/diversity-and-inclusion/pronoun-use-in-email-signatures/>**)*
> Geodetic Scientist
> Location Information
> ccrook at linz.govt.nz <mailto:ccrook at linz.govt.nz> | *DDI *04 460 0567 |
> *MOB* 021 027 44211
> _cid:image001.png at 01D622F4.BA10B4F0 <https://www.linz.govt.nz/>_
> Wellington Office, Level 7, Radio New Zealand House, 155 The Terrace
> PO Box 5501, Wellington 6145, New Zealand
> _www.linz.govt.nz <http://www.linz.govt.nz/>_ | _data.linz.govt.nz
> <http://www.data.linz.govt.nz/>_
> _cid:image002.png at 01D6342C.DB5A4560
> <https://www.facebook.com/landinformationnz/>__cid:image004.png at 01D6342C.DB5A4560
> <https://www.linkedin.com/company/land-information-new-zealand/>__cid:image006.png at 01D6342C.DB5A4560
> <https://twitter.com/LandInfoNZ>__cid:image011.png at 01D6342C.DB5A4560
> <https://www.youtube.com/user/linzvideoofficial>_
> This message contains information, which may be in confidence and may
> be subject to legal privilege. If you are not the intended recipient,
> you must not peruse, use, disseminate, distribute or copy this
> message. If you have received this message in error, please notify us
> immediately (Phone 0800 665 463 or customersupport at linz.govt.nz) and
> destroy the original message. LINZ accepts no responsibility for
> changes to this email, or for any attachments, after its transmission
> from LINZ. Thank You.
> UNCLASSIFIED
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
Mood of the day: "Bien entendu, on peut sauter sur sa chaise comme un cabri en disant : les standards ! les standards ! les standards ! Mais ça n’aboutit à rien et ça ne signifie rien." ~ dixit De Gaulle
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20241220/6c2c928b/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20241220/6c2c928b/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20241220/6c2c928b/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20241220/6c2c928b/attachment-0007.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20241220/6c2c928b/attachment-0008.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20241220/6c2c928b/attachment-0009.png>
More information about the PROJ mailing list
