[PROJ] PROJ 9.4.1RC1 & PROJ-data 1.18RC1
    Javier Jimenez Shaw
    j1 at jimenezshaw.com
    Sat Jun  1 00:36:50 PDT 2024
+1 Javier
On Sat, 1 Jun 2024, 07:23 Kristian Evers via PROJ, <proj at lists.osgeo.org>
wrote:
> Apart from the issue with the ._-files in the PROJ-data packages no issues
> has been reported. I hereby motion that both release candidates be promoted
> to final releases. I'll start with my +1.
> /Kristian
> man. 27. maj 2024 21.42 skrev Kristian Evers <kristianevers at gmail.com>:
>> All,
>> It’s time for another round of releases, so in preparation for the final
>> packages I have uploaded
>> release candidates for PROJ and PROJ-data. Download the archives here:
>> https://download.osgeo.org/proj/proj-9.4.1RC1.tar.gz
>> https://download.osgeo.org/proj/proj-9.4.1RC1.zip
>> https://download.osgeo.org/proj/proj-data-1.18RC1.tar.gz
>> https://download.osgeo.org/proj/proj-data-1.18RC1.zip
>> The PROJ release includes updates to the database contents and bug fixes.
>> See the release notes below.
>> The PROJ-data release adds transformation models for the Danish vertical
>> CRS’s DKLAT and DKMSL as well
>> as the Greenlandic GLLMSL.
>> Please test the release candidates and report any issues you may find.
>> Either here on the mailing list or on GitHub.
>> /Kristian
>> # PROJ Release Notes
>> ## 9.4.1
>> ### Updates
>> * Database: update to EPSG v11.006 (#4086)
>> * Database: update ESRI dataset to ArcGIS Pro 3.3 (#4143)
>> ### Bug fixes
>> * DatabaseContext::lookForGridInfo(): do not trigger network activity in
>> PROJ_GRID_AVAILABILITY_KNOWN_AVAILABLE mode when all grids are known
>> (#4090)
>> * Retry "Connection reset by peer" (#4107)
>> * Use unique names for NKG transformations (#4111)
>> * proj_create()/proj_create_from_database(): recall CRS AUTH:CODE in
>> error message (#4114)
>> * DerivedProjectedCRS: deal with lack of explicit CS in BASEPROJCRS in
>> WKT (#4139)
>> * proj_symbol_rename.h: update with current symbols (#4145)
>> * Improve detection of compatible/incompatible celestial bodies (#4150)
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240601/e078e393/attachment.htm>
More information about the PROJ
