[PROJ] WGS 84 to GDA2020 in EPSG
Even Rouault
even.rouault at spatialys.com
Thu May 9 05:40:29 PDT 2024
Javier,
you might perhaps find some hints at
https://www.ga.gov.au/scientific-topics/positioning-navigation/geodesy/transform-convert
or
https://www.icsm.gov.au/sites/default/files/2021-10/GDA2020%20Technical%20Manual%20V1.7.pdf
. There are also a number of (closed) issues on PROJ tracker about that,
because that confuses everybody, but I believe the answer is that all
and none of the 3 transformations is correct, because there is no
universal answer. Mostly comes from the fact that GDA94 & GDA2020 are
plate-anchored and WGS 84 (as EPSG:4326) is a global datum ensemble with
an accuracy of 2 m.
There are time-dependent transformations between GDA94 and WGS 84
(G1762), and GDA2020 and WGS 84 (G1762), but for generic WGS 84, things
are more fuzzy, as one might consider that GDA94 = WGS 84 (at 1994.0)
and GDA2020 = WGS 84 (at 2020.0).
So when you do WGS84 to GDA2020, if you are talking about coordinates
with an epoch of ~ 2020, then the null Helmert transformation is
appropriate, since by definition GDA2020 = ITRF2014 at 2020.0 ~= WGS84
at 2020
But if you are considering WGS84 coordinates with an epoch of ~ 1994.0,
then WGS84 ~= GDA94, and it makes sense then to propose the
transformations between GDA94 and GDA2020, hence (3) and (4). As far as
I remember the "standard" conformal transformation between GDA94 and
GDA2020 is the (non-null) 7-Helmert, and a NTv2 grid
(GDA94_GDA2020_conformal) was just derived from this 7-Helmert
transformation because some software prefer grids to Helmert
transformation. The proposed WGS 84 to GDA2020 (4) actually uses
GDA94_GDA2020_conformal_and_distortion, which is a variation of the
conformal grid that takes into account some distortion (cf paragraph
3.2.2 of the GDA2020 technical manual)
I suspect the 3m accuracy was given so that none of the 3
transformations particularly appear as better as the others, as
ultimately the user needs to decide what "type of WGS 84" he has.
Just my non-authoritative guesses.
Even
Le 09/05/2024 à 12:47, Javier Jimenez Shaw via PROJ a écrit :
> Hi
> Preparing a talk for FOSS4G Europe in Tartu (see you there if you
> come!), I found that the 3 transformations in EPSG from WGS 84 to
> GDA2020 (2, 3 and 4) they all have 3m accuracy.
> That is not giving a clue to PROJ about which one is better.
> (2) is a null Helmert transformation.
> (3) is a Helmert with 7 numbers
> (4) uses a grid.
> Is there anybody from the Australian agency here? Is there any reason
> why the three transformations have the same accuracy? I would expect
> different values. I looks like a copy-paste issue.
> The same happens with the transformation from WGS 84 to GDA94.
> Thanks,
> Javier
> .___ ._ ..._ .. . ._. .___ .. __ . _. . __.. ... .... ._ .__
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240509/d1b18b8a/attachment.htm>
More information about the PROJ
