[PROJ] Make push and pop FIFO?
Lesparre, Jochem
Jochem.Lesparre at kadaster.nl
Fri May 10 01:07:03 PDT 2024
Even and Thomas,
Sorry, it wasn't my intention to criticise you. It seems that I didn't use the proper wording to express my honest believe that PROJ deserves a better solution. My apologies! I recognise that the discussion between you two on how to solve this issue demonstrates your dedication to PROJ, which I really appreciate.
I'm more than willing to convince people in my organisation that next to using PROJ we should also contribute to PROJ with code to solve this issue. However, it is hard to do that if there is no consensus on the way to solve it. There is no point in doing a pull request for us, if it won't be merged into a next PROJ release. (We normally publish a single PROJ pipeline for the 3D to 2D+1D transformation, that our users can implement themselves using a recent PROJ version. Splitting it in a 3D to 2D transformation and a 3D to 1D transformation makes it more prone to mistakes in the implementation.)
If we would do a pull request, I think it would be best to keep it as limited as possible, to maximise the change of obtaining consensus, right? So I would suggest not to change +push and +pop and only add one simple new operation, something like +proj=stackswap +order=2,1 which would swap the top two values on the stack for all 4 coordinate components.
Jochem
Disclaimer:
De inhoud van deze e-mail is vertrouwelijk en uitsluitend bestemd voor de geadresseerde(n).
Gebruik, openbaarmaking, vermenigvuldiging, verspreiding en/of verstrekking van deze informatie aan derden is niet toegestaan.
Op al onze producten en diensten zijn onze algemene leveringsvoorwaarden van toepassing
[https://www.kadaster.nl/algemene-leveringsvoorwaarden].
Disclaimer:
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you are not the intended recipient, you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Our general terms and conditions of delivery apply to all our products and services
[https://www.kadaster.com/general-terms-and-conditions].
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240510/f063b3ca/attachment-0001.htm>
More information about the PROJ
