[PROJ] PROJ 9.4.1RC1 & PROJ-data 1.18RC1
Even Rouault even.rouault at spatialys.com
Mon May 27 14:29:05 PDT 2024
We still have the same issues with the proj-data archive containing
MacOS dot-starting files. I've taken the liberty to generate a RC2 of it
by removing them with the following procedure run on the server:
  mkdir tmp
  cd tmp
  tar xvzf ../proj-data-1.18RC1.tar.gz
  rm ._*
  tar cvzf ../proj-data-1.18RC2.tar.gz *
So:
https://download.osgeo.org/proj/proj-data-1.18RC2.tar.gz
https://download.osgeo.org/proj/proj-data-1.18RC2.zip
Otherwise, I was surprised to see that we only shipped EPSG 11.006 and
not 11.008 as in master, but I then found out that the backports of
https://github.com/OSGeo/PROJ/pull/4093 (11.007 update) and
https://github.com/OSGeo/PROJ/pull/4132 (11.008 updates) had failed, but
we didn't notice. The issue is that the message posted by the bot is
posted with the credentials of the PR author, so the PR author doesn't
receive it, and doesn't realize that the automated backport has failed.
There must be something with the way with the bot is configured (I see
that in QGIS the message is posted by another account, so the PR author
receives an email). Anyway, I don't think there was anything particular
life critical in those updates, so they can probably wait for 9.5 .
https://github.com/OSGeo/PROJ/pull/4098 also didn't make it, but also
not business critical
Even
Le 27/05/2024 à 21:42, Kristian Evers via PROJ a écrit :
> All,
> It’s time for another round of releases, so in preparation for the final packages I have uploaded
> release candidates for PROJ and PROJ-data. Download the archives here:
> https://download.osgeo.org/proj/proj-9.4.1RC1.tar.gz
> https://download.osgeo.org/proj/proj-9.4.1RC1.zip
> https://download.osgeo.org/proj/proj-data-1.18RC1.tar.gz
> https://download.osgeo.org/proj/proj-data-1.18RC1.zip
> The PROJ release includes updates to the database contents and bug fixes. See the release notes below.
> The PROJ-data release adds transformation models for the Danish vertical CRS’s DKLAT and DKMSL as well
> as the Greenlandic GLLMSL.
> Please test the release candidates and report any issues you may find. Either here on the mailing list or on GitHub.
> /Kristian
> # PROJ Release Notes
> ## 9.4.1
> ### Updates
> * Database: update to EPSG v11.006 (#4086)
> * Database: update ESRI dataset to ArcGIS Pro 3.3 (#4143)
> ### Bug fixes
> * DatabaseContext::lookForGridInfo(): do not trigger network activity in
> PROJ_GRID_AVAILABILITY_KNOWN_AVAILABLE mode when all grids are known (#4090)
> * Retry "Connection reset by peer" (#4107)
> * Use unique names for NKG transformations (#4111)
> * proj_create()/proj_create_from_database(): recall CRS AUTH:CODE in error message (#4114)
> * DerivedProjectedCRS: deal with lack of explicit CS in BASEPROJCRS in WKT (#4139)
> * proj_symbol_rename.h: update with current symbols (#4145)
> * Improve detection of compatible/incompatible celestial bodies (#4150)
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
More information about the PROJ mailing list
