[PROJ] PROJ (and GDAL) webpages
Even Rouault
even.rouault at spatialys.com
Fri Nov 15 04:30:53 PST 2024
Javier,
> I have the impression (maybe I misunderstood) that both the automatic
> redirection and the robots should be pointing to "stable". (GDAL
> didn't have "stable" url at the beginning, I know)
> That will make search engine indexers don't have to remake the index,
> with the consequent degradation in the position. Also will not point
> somebody to an old version of the software. It is good that the old
> versions are there in case you need it, but search engines should
> point to "stable" (and IMHO not to latest, with functionalities that
> are may not be released yet).
> What do you think?
The annoying thing with "stable" is that it points to the latest
released *tag*, not the head of the release branch, so bugfixes in the
doc after the release don't appear until the next one.
> There was a problem in PROJ after the last release. Maybe we can fix
> it to be ready for the next release in a couple of weeks.
Refresh our minds about which problem you're thinking too (don't we
spend our time solving problems) :-) ?
One problem I've in mind with the "stable" RTD tag is that when you
prepare the release, you need in advance to update the doc to advertize
the release *before* creating the tag. For example
https://proj.org/en/stable/download.html doesn't point to the 9.5.0
release, because the commit that advertizes it was done just after. For
GDAL, I've adjusted the release procedure so that step is done in advance.
Bottom line: I would be in favor of pointing to "stable" if we could
tweak the RTD configuration to point to a branch of our choice, but I
don't think that's currently possible.
Another thought: the GDAL user survey currently advertized on gdal.org
couldn't be advertized if the default was the stable RTD tag
EDIT: actually looking at
https://docs.readthedocs.io/en/stable/versions.html, I do read "If you
want a custom |stable| version, create either a tag or branch in your
project with that name.". So maybe we should just create a git "stable"
branch, but that means we need to regularly resync it to the actual HEAD
of the active 9.x git branch
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20241115/98abfab8/attachment.htm>
More information about the PROJ
