[PROJ] PROJ 9.5.1RC1 & PROJ-data 1.20RC1
Even Rouault even.rouault at spatialys.com
Tue Nov 26 06:16:05 PST 2024
Kristian,
This is a side effect of the logic to get faster database builds, which
is affected when the version number is changed. So indeed
data/CMakeLists.txt must be adjusted with the provided value
I've also submitted https://github.com/OSGeo/PROJ/pull/4330 to add the
needed step in the release procedure.
Even
Le 26/11/2024 à 14:50, Sebastiaan Couwenberg via PROJ a écrit :
> On 11/26/24 9:10 AM, Kristian Evers via PROJ wrote:
>> As always, please test the release candidates and report any issues
>> you may find. Either here on the mailing list or on GitHub.
> Debian package fails to build:
>  CMake Error at generate_proj_db.cmake:45 (message):
>    Update 'set(PROJ_DB_SQL_EXPECTED_MD5 ...)' line in
> data/CMakeLists.txt with
>    0491c73526276ee8e99fe8f4597f9565 value
>  make[3]: *** [data/CMakeFiles/generate_proj_db.dir/build.make:122:
> data/proj.db] Error 1
>  make[3]: Leaving directory '/build/proj-9.5.1~rc1/obj-x86_64-linux-gnu'
>  make[2]: *** [CMakeFiles/Makefile2:1412:
> data/CMakeFiles/generate_proj_db.dir/all] Error 2
>  make[2]: *** Waiting for unfinished jobs....
> Kind Regards,
> Bas
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
More information about the PROJ mailing list
