[PROJ] PROJ 9.5.1RC1 & PROJ-data 1.20RC1
Javier Jimenez Shaw
j1 at jimenezshaw.com
Wed Nov 27 07:32:24 PST 2024
On Tue, 26 Nov 2024 at 09:11, Kristian Evers via PROJ <proj at lists.osgeo.org>
wrote:
> In anticipation of the releases scheduled for December 1st, I have
> prepared release candidates
> for both PROJ and PROJ-data. Download the archives here:
> https://download.osgeo.org/proj/proj-9.5.1RC1.tar.gz
> https://download.osgeo.org/proj/proj-9.5.1RC1.zip
> https://download.osgeo.org/proj/proj-data-1.20RC1.tar.gz
> https://download.osgeo.org/proj/proj-data-1.20RC1.zip
> The PROJ-data adds grids for use in Hungary and Thüringen, Germany.
> See the release notes for PROJ below.
> As always, please test the release candidates and report any issues you
> may find. Either here on the mailing list or on GitHub.
> /Kristian
> # PROJ Release Notes
> ## 9.5.1
> ### Updates
> * Database: update to EPSG v11.021 (#4254, #4275, #4297)
I think we are already in 11.022
https://github.com/OSGeo/PROJ/commit/6ab8ec8ee
> * Speed-up dramatically proj.db build time (#4280)
> * Database: ingest deprecated ESRI names to be able to better import old
> WKT ESRI (#4282)
> ### Bug fixes
> * `findsOpsInRegistryWithIntermediate()`: Restrict to using known
> source/target CRS that have the same originating authority (#4252)
> * `isTimeDependent()`: Do not mark "static" Coordinate Frame helmert
> transformations as time-dependent, only time-dependent ones (#4259)
> * Fix clang-19 "warning: empty paragraph passed to '@throw' command
> [-Wdocumentation]" (#4263)
> * WKT importer: fix `nullptr` dereference on invalid `VERTCS[]` (#4266)
> * Fixed `sql_filelist.cmake` relative path issue (#4296)
> * Fail consistently on network error and grid transformations (#4302)
> * Fix `-Wshadow` warnings between `parammappings.cpp` and
> `singleoperation.cpp` with unity builds (#4304)
> * Removed leftover setting of `CMAKE_REQUIRED_FLAGS` (#4322)
> * WKT1 ESRI export: fix wrong mapping of Lambert Cylindrical Equal Area to
> Behrmann (#4328)
> * Numerous documentation fixes (#4248, #4267, #4291, #4293)
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20241127/3aed3afa/attachment.htm>
More information about the PROJ
