[PROJ] RFC 102: Embedding resource files into libgdal (and PROJ)
Even Rouault
even.rouault at spatialys.com
Tue Oct 1 09:54:29 PDT 2024
Sending to both gdal-dev and proj, as this is intended to be a joint RFC.
Summary: This RFC uses C23 ``#embed`` pre-processor directive, when
available, to be able to embed GDAL resource files directly into
libgdal. It is also intended to be used for PROJ, in particular for its
proj.db file.
Details: See https://github.com/OSGeo/gdal/pull/10913
Even
http://www.spatialys.com
More information about the PROJ
