[PROJ] [gdal-dev] RFC 102: Embedding resource files into libgdal (and PROJ)
Kurt Schwehr
schwehr at gmail.com
Wed Oct 2 12:03:06 PDT 2024
So excited for this feature. We have custom code that does stuff like this.
e.g.
+ // BEGIN GOOGLE MODIFICATION
+ int flags = SQLITE_OPEN_READONLY | SQLITE_OPEN_NOMUTEX;
if (path.empty()) {
- path.resize(2048);
- const bool found =
- pj_find_file(pjCtxt(), "proj.db", &path[0], path.size() - 1)
!= 0;
- path.resize(strlen(path.c_str()));
- if (!found) {
- throw FactoryException("Cannot find proj.db");
+ static const FileToc *toc = [] {
+ // Enable the memvfs extension.
+ const int init_code = sqlite3_memvfs_init(nullptr, nullptr,
nullptr);
+ if (init_code != SQLITE_OK_LOAD_PERMANENTLY) {
+ throw FactoryException(
+ absl::StrCat("Can't initialize memvfs, with code ",
init_code));
+ // Re-register 'unix' as default filesystem. MemVFS can be used
+ // through URL parameters, or by passing as the fourth argument
to
+ // sqlite3_open_v2().
+ const int register_code =
+ sqlite3_vfs_register(sqlite3_vfs_find("unix"), /*makeDflt
=*/1);
+ if (register_code != SQLITE_OK) {
+ throw FactoryException(absl::StrCat(
+ "Can't re-register the default VFS, with code ",
init_code));
+ return proj_db_create();
+ // Load the database from a cc_embed_file, using the memvfs
+ // extension of sqlite.
+ path =
absl::StrFormat("file:/proj?ptr=0x%x&sz=%d&max=%d&vfs=memvfs",
+ reinterpret_cast<uintptr_t>(toc[0].data),
+ toc[0].size, toc[0].size);
+ flags |= SQLITE_OPEN_URI;
+ // END GOOGLE MODIFICATION
On Tue, Oct 1, 2024 at 10:28 AM Even Rouault via PROJ <proj at lists.osgeo.org>
wrote:
> Greg,
> What's unclear is to what extent things continue to be ok on compilers
> not supporting C23, and if they are, if those systems start to be second
> class. My overall feeling is that it is vastly too early to be
> depending on C23.
> The RFC is clear enough this is an optional feature ("C23 is not required
> if EMBED_RESOURCE_FILES is not enabled"). If you need it, you will need a
> C23 compiler, which there is already one available (clang 19), and another
> one in a near future (gcc 15).
> C23 is only used to build the .c files where resources are embedded.
> If you don't need that new feature, you can use the current minimum build
> requirements of GDAL/PROJ.
> For once that GDAL/PROJ can use shiny new stuff, let's enjoy :-)
> But maybe c23 is c2x, and it's been supported in gcc for 6 years.
> No way a gcc from 6 years ago can support #embed: support has literally
> landed in GCC master 2 weeks ago.
> -- http://www.spatialys.com
> My software is free, but my time generally not.
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20241002/feb0ec55/attachment.htm>
More information about the PROJ
