[PROJ] general use of proj_factors
Even Rouault even.rouault at spatialys.com
Fri Oct 25 05:57:54 PDT 2024
> I guess this will be available in a beta release? If so, I can check
> that to see how the addition effects things.
No we don't do that. Just build from git master source once merged (or
better test the PR, or apply it your PROJ sources if you build it frmo
source already. I presume that should apply just fine on top of 9.4)
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20241025/a53f64e0/attachment.htm>
More information about the PROJ mailing list
