[PROJ] Geodetic to Authalic latitude conversions
Even Rouault even.rouault at spatialys.com
Wed Sep 11 02:30:03 PDT 2024
> We will surely find out when we run the unit tests for those projections?
Not sure which tolerance they have and how much those projections are
tested (do not forget that much of the regression test suite was
automatically generated with the results PROJ produced at that time, so
with quite generic tolerances, etc.). I was more thinking about manually
testing with proj/cct binaries before and after, and see the differences
>> It is also not immediately obvious to me to correlate your proposed
>> code with the formulas in the paper by just starring at both at the
>> same time. Looks like some "interpretation" of the paper has been done.
> It's quite straightforward, but optimized for the precalculations like
> PROJ was doing in /auth.cpp/. There is no "interpretation" involved.
Well, what you mention below is what I call "interpretation", that is
not direct copying of ready-made formulas, where someone unqualified
could trivially check if there's no typo ;-)
> It is of course still possible that I made a mistake with all this,
> but I imagine that updating this and running the tests should help to
> be confident about the results.
Running the existing PROJ test suite will show if the new formulas are
consistent with the current less precise ones with maybe a quite loose
tolerance, not necessarily that we reach the new level of precision we
claim. Hence comparing with some random test points against
GeographicLib which can hopefully be considered as a reference
implementation, to check we have identical results (or at least share
more common decimals up to the desired precision)
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240911/361e1360/attachment.htm>
More information about the PROJ mailing list
