[PROJ] Geodetic to Authalic latitude conversions
Charles Karney
charles.karney at gmail.com
Thu Sep 12 05:09:29 PDT 2024
I recommend against unrolling the loops. This makes the code longer and
harder to read. You also lose the flexibility of adjusting the number
of terms in the expansion at runtime.
I'm not an expert of the minutiae of code optimization and my preference
would normally be to keep the code simple and understandable. But
remember that compilers can do the loop unrolling for you. Also,
doesn't the smaller code size with the loops result in fewer cache
misses?
Maybe polyval can go into a header file to get inlined. But remember
that this is needed relatively rarely when setting up the coefficients
for a particular ellipsoid. So it's probably now contributing much to
the overall CPU cost.
It is possible to do 2x unroll of the Clenshaw loop to avoid the
shuffling of variables (t = xx(u0, u1), u1 = u0, u0 = t). See the
function SinCosSeries in geodesic.c where this is done.
Undoubtedly, we could do a better job centralizing some of these core
capabilities, Clenshaw (and its complex counterpart) + general auxiliary
latitude conversions, so that we don't have essentially duplicate code
scattered all over the place.
On Wed, Sep 11, 2024 at 10:44 PM Jérôme St-Louis <jerome at ecere.com> wrote:
> Dear Even, Charles, Thomas, All,
> Please find below a couple revised implementations of the authalic ==> geodetic conversion using Horner's method and Clenshaw summation algorithm, both sharing this table of coefficients from A20:
> #define AUTH_ORDER 6
> static const double Cphimu[21] = // Cφξ (A20) - coefficients to convert authalic latitude to geodetic latitude
> 4 / 3.0, 4 / 45.0, -16/35.0, -2582 /14175.0, 60136 /467775.0, 28112932/ 212837625.0,
> 46 / 45.0, 152/945.0, -11966 /14175.0, -21016 / 51975.0, 251310128/ 638512875.0,
> 3044/2835.0, 3802 /14175.0, -94388 / 66825.0, -8797648/ 10945935.0,
> 6059 / 4725.0, 41072 / 93555.0, -1472637812/ 638512875.0,
> 768272 /467775.0, -455935736/ 638512875.0,
> 4210684958/1915538625.0
> This first one is using the existing functions from mlfn.cpp (untouched other than possibly different formatting here):
> // Evaluate sum(p[i] * x^i, i, 0, N) via Horner's method (p is of length N+1)
> static inline double polyval(double x, const double p[], int N)
> double y = N < 0 ? 0 : p[N];
> while(N > 0)
> y = y * x + p[--N];
> return y;
> // Evaluate y = sum(c[k] * sin((2*k+2) * zeta), k, 0, K-1)
> static inline double clenshaw(double szeta, double czeta, const double c[], int K)
> // Approx operation count = (K + 5) mult and (2 * K + 2) add
> double u0 = 0, u1 = 0; // accumulators for sum
> double X = 2 * (czeta - szeta) * (czeta + szeta); // 2 * cos(2*zeta)
> while(K > 0)
> double t = X * u0 - u1 + c[--K];
> u1 = u0;
> u0 = t;
> return 2 * szeta * czeta * u0; // sin(2*zeta) * u0
> // https://arxiv.org/pdf/2212.05818
> // ∆η(ζ) = S^(L)(ζ) · Cηζ · P^(M) (n) + O(n^L+1) -- (20)
> void pj_authset(double a, double b, double cp[AUTH_ORDER])
> double n = (a - b) / (a + b); // Third flattening
> double d = n;
> int l, o;
> for(l = 0, o = 0; l < AUTH_ORDER; l++)
> int m = AUTH_ORDER - l - 1;
> cp[l] = d * polyval(n, Cphimu + o, m);
> d *= n;
> o += m + 1;
> double pj_auth2geodlat(const double * cp, double phi)
> return phi + clenshaw(sin(phi), cos(phi), cp, AUTH_ORDER);
> For this second implementation, I unrolled the loops to get rid of the iterations (and associated counter incrementations) and conditionals, which if the compiler is not optimizing out, could potentially introduce some branching costs.
> This unrolled version remains quite compact (at least in this particular formatting which the pre-commit hook will certainly massacre). The sequence of operations is exactly the same, and I've tested that the two are equivalent, and also equivalent with the two earlier implementations that I shared which were not using Horner and Clenshaw, and also equivalent to 8 decimals to the existing pj_authlat() function in PROJ.
> // Precomputing coefficient based on Horner's method
> const double * C = Cphimu;
> double d = n;
> cp[0] = (((((C[ 5] * n + C[ 4]) * n + C[ 3]) * n + C[ 2]) * n + C[ 1]) * n + C[ 0]) * d, d *= n;
> cp[1] = (((( C[10] * n + C[ 9]) * n + C[ 8]) * n + C[ 7]) * n + C[ 6]) * d, d *= n;
> cp[2] = ((( C[14] * n + C[13]) * n + C[12]) * n + C[11]) * d, d *= n;
> cp[3] = (( C[17] * n + C[16]) * n + C[15]) * d, d *= n;
> cp[4] = ( C[19] * n + C[18]) * d, d *= n;
> cp[5] = C[20] * d;
> // Using Clenshaw summation algorithm (order 6)
> double szeta = sin(phi), czeta = cos(phi);
> double t;
> t = X * u0 - u1 + cp[5], u1 = u0, u0 = t;
> t = X * u0 - u1 + cp[4], u1 = u0, u0 = t;
> t = X * u0 - u1 + cp[3], u1 = u0, u0 = t;
> t = X * u0 - u1 + cp[2], u1 = u0, u0 = t;
> t = X * u0 - u1 + cp[1], u1 = u0, u0 = t;
> t = X * u0 - u1 + cp[0];
> return phi + /* sin(2*zeta) * u0 */ 2 * szeta * czeta * t;
> Note that the output of these two versions of pj_authset() (the 6 constants precomputed from the authalic ==> geodetic A20 conversion matrix and the ellipsoid's third flattening) is exactly the same as the previous version not using Horner's method, and I believe also the same as the current output of pj_autset() except that it currently uses only 3 constants for order 3 rather than 6 for order 6.
> With both of these versions, we're down to only one sin() and one cos() call, as per Even's suggestion, so I imagine that the Clenshaw algorithm does take advantage of that trigonometric identity trick.
> If we go with the separate polyval() and clenshaw() functions, then I suggest we move these functions to a header file so that we can share them between mlfn.cpp and auth.cpp while allowing the compiler to hopefully efficiently inline them, and also hopefully optimize the code close to or equivalent to the unrolled version (we could always compare the disassembly to verify whether this is the case or not, but I would leave that to others).
> My own preference would be for the unrolled version.
> We could also make C / Cphimu a parameter to pj_authset() (which could be named something else), since this could be used for other conversions between auxiliary latitudes.
> Similarly, pj_auth2geodlat() could actually be used for different conversions if passing it pre-computed coefficients for other conversions, so perhaps it could have a more generic names.
> The rectifying latitude for pj_enfn() is a bit special because it uses n^2 rather than n, which tripped me up for a little while.
> Thoughts / suggestions on how to move forward with this?
> As a next step I would prepare a Pull Request based on your feedback, if you have a preference for the shared functions or the unrolled loops approach.
> Thank you very much for your help and guidance!
> Kind regards,
> -Jerome
> On 9/11/24 4:21 PM, Jérôme St-Louis wrote:
> So it seems like we already have an implementation of Horner and Clenshaw in:
> https://github.com/OSGeo/PROJ/blob/master/src/mlfn.cpp
> called polyval() and clenshaw() just like in GeographicLib ( polyval() , Clenshaw()).
> It seems like Charles wrote or at least updated that :)
> That is using the Cµφ (C[mu phi]) (A5) and Cφµ (C[phi mu]) (A6) from page 12 of the paper, where µ is called the "rectifying latitude".
> I imagine that this is directly related to the "meridional distance" ?
> Perhaps we could re-organize this a bit to share this polyval() and clenshaw() (they are currently static functions local to this mlfn.cpp) for use in auth.cpp ?
> Thanks!
> Kind regards,
> -Jerome
> On 9/11/24 3:33 PM, Jérôme St-Louis wrote:
> Thanks a lot for the input Charles and Thomas,
> I am not familiar with either Horner or Clenshaw, but I do see the mentions now on Section 6 - Evaluating the series pages 6 and 7 of the papers.
> I implemented the simpler basic approach from section 3 / page 3, which also happened to more easily correspond to the existing PROJ implementation.
> I can definitely try to understand all this, with the help of this Rust Geodesy code and the GeographicLib code, and have a go at updating my proposed implementation for improved accuracy and performance.
> Kind regards,
> -Jerome
> On 9/11/24 12:18 PM, Thomas Knudsen wrote:
> I totally agree with Charles regarding using Horner for polynomial
> evaluation and Clenshaw for the trig series - for accuracy and speed.
> I implemented all the material from Charles' preprint
> https://arxiv.org/pdf/2212.05818 for Rust Geodesy, when the preprint
> appeared about 1½ years ago.
> And although (being an experiment) my handling of the raw coefficients
> is rather clumsy, at least it gave me a reason to revise my PROJ horner
> and clenshaw implementations (which in turn were based on material from
> Poder & Engsager: "Some Conformal Mappings...").
> So Jérôme, perhaps take a look at the functions "taylor" and "fourier"
> over at https://github.com/busstoptaktik/geodesy/blob/main/src/math/series.rs
> While written in Rust, translating to C++ should be rather trivial,
> and they may be easier to follow than my decade-old versions already
> in the PROJ code base.
Charles Karney <karney at alum.mit.edu>
702 Prospect Ave
Princeton, NJ 08540
More information about the PROJ
