[PROJ] PROJ 9.5.0RC1 & PROJ-data 1.19RC1
Javier Jimenez Shaw j1 at jimenezshaw.com
Fri Sep 13 00:02:27 PDT 2024
+1 Javier
On Fri, 13 Sept 2024, 08:38 Kristian Evers via PROJ, <proj at lists.osgeo.org>
wrote:
> PSC members,
> No issues have been reported with either of the release candidates so I’ll
> put their promotion to final releases up for a vote.
> I’ll start with my +1.
> /Kristian
> > On 9 Sep 2024, at 14.01, Kristian Evers <kristianevers at gmail.com> wrote:
> > All,
> > in preparation for a new round of PROJ and PROJ-data release I have
> uploaded release candidates for both packages.
> > Download the archives here:
> > https://download.osgeo.org/proj/proj-9.5.0RC1.tar.gz
> > https://download.osgeo.org/proj/proj-9.5.0RC1.zip
> > https://download.osgeo.org/proj/proj-data-1.19RC1.tar.gz
> > https://download.osgeo.org/proj/proj-data-1.19RC1.zip
> > The PROJ release includes various updates and bug fixes. See the release
> notes below.
> > The PROJ-data release is updated with grids related to the Greenlandic
> GLMSL and GLLAT.
> > Please test the release candidates and report any issues you may find
> with them.
> > Either here on the mailing list or on GitHub.
> > /Kristian
> > ## 9.5.0
> > ### Updates
> > * Database: add constraint for unicity of CRS and operation names (#4071)
> > * Make a few more functions that accept a `PJ*` to actually acccept a
> `const PJ*` (#4074)
> > * Database: Increase consistency in trigger checks (#4080)
> > * Speed-up `+proj=cart +inv` (#4087)
> > * Added EPSG:9656 "Cartesian Grid Offsets" operation method, and
> imported related records (#4094)
> > * Add a `WKTParser::grammarErrorList()` method so that
> `proj_create_from_wkt()` can behave as documented (#4108)
> > * `CRS::stripVerticalComponent()`: Redirect it to
> `demoteTo2D(std::string(), nullptr)` (#4127)
> > * Add `proj_context_set_user_writable_directory()` to public API (#4144)
> > * CMake: for Windows builds, defaults PROJ DLL to be just
> `proj_${PROJ_MAJOR_VERSION}.dll` (#4167)
> > * Add `toWGS84AutocorrectWrongValues()` method and use it in PROJ.4 and
> WKT1 CRS import (#4172)
> > * WKT import: add support for Oracle WKT "Albers_Conical_Equal_Area"
> spelling (#4181)
> > * Limit number of C++ exceptions thrown & caught internally (#4183)
> > * Database: update to EPSG 11.016 (#4241)
> > * CMake: add option `EMBED_PROJ_DATA_PATH` (#4207)
> > * Add SEA Inverse projection (#4211)
> > * projinfo: Add 2 args equivalent to usage of `-s` and `-t` (#4218)
> > * CMake: add TESTING_USE_NETWORK configure option (#4220)
> > * Add `PROJ_ERR_COORD_TRANSFM_MISSING_TIME` and
> `proj_coordoperation_requires_per_coordinate_input_time()` (#4221)
> > * Add new Conversion "Local Orthographic" (#4228, #4229)
> > * Add data/ITRF2020 with ITRF2020 to ITRFother, and ITRF2020 plate
> motion models (#4235)
> > ### Bug Fixes
> > * Fix `imoll` and `imoll_o` zone calculations to correct inverse
> transformations near the "seams" (#4159)
> > * Fix wrong EPSG conversion code for UTM south (#4166)
> > * BoundCRS::exportToPROJ(): handle case of NADCON conus grid (#4168)
> > * `+proj=gridshift`: make projected grids work with `PROJ_NETWORK=ON`
> (#4174)
> > * `createOperations()`: make it work when transforming from/to a
> CompoundCRS with a DerivedVerticalCRS with ellipsoidal height (#4176)
> > * Support default context as `nullptr` in `CoordinateTransformer` (#4177)
> > * cct: emit error message and return error code when not being able to
> open input file (#4200)
> > * Fix race condition surrounding DB reopening during fork (#4231)
> > * `GeographicBoundingBox::create()`: accept degenerate bounding box
> reduced to a point or a line (#4237)
> > * `createOperation()`: tune so that ITRF2000->ETRS89 does not return
> only NKG grid based operations but also time-dependent Helmert (#4244)
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240913/6993e73d/attachment-0001.htm>
More information about the PROJ mailing list
