[PROJ] PROJ 9.5.0RC1 & PROJ-data 1.19RC1
Howard Butler howard at hobu.co
Fri Sep 13 04:54:43 PDT 2024
+1 Howard
> On Sep 13, 2024, at 1:37 AM, Kristian Evers via PROJ <proj at lists.osgeo.org> wrote:
> PSC members,
> No issues have been reported with either of the release candidates so I’ll
> put their promotion to final releases up for a vote.
> I’ll start with my +1.
> /Kristian
>> On 9 Sep 2024, at 14.01, Kristian Evers <kristianevers at gmail.com> wrote:
>> All,
>> in preparation for a new round of PROJ and PROJ-data release I have uploaded release candidates for both packages.
>> Download the archives here:
>> https://download.osgeo.org/proj/proj-9.5.0RC1.tar.gz
>> https://download.osgeo.org/proj/proj-9.5.0RC1.zip
>> https://download.osgeo.org/proj/proj-data-1.19RC1.tar.gz
>> https://download.osgeo.org/proj/proj-data-1.19RC1.zip
>> The PROJ release includes various updates and bug fixes. See the release notes below.
>> The PROJ-data release is updated with grids related to the Greenlandic GLMSL and GLLAT.
>> Please test the release candidates and report any issues you may find with them.
>> Either here on the mailing list or on GitHub.
>> /Kristian
>> ## 9.5.0
>> ### Updates
>> * Database: add constraint for unicity of CRS and operation names (#4071)
>> * Make a few more functions that accept a `PJ*` to actually acccept a `const PJ*` (#4074)
>> * Database: Increase consistency in trigger checks (#4080)
>> * Speed-up `+proj=cart +inv` (#4087)
>> * Added EPSG:9656 "Cartesian Grid Offsets" operation method, and imported related records (#4094)
>> * Add a `WKTParser::grammarErrorList()` method so that `proj_create_from_wkt()` can behave as documented (#4108)
>> * `CRS::stripVerticalComponent()`: Redirect it to `demoteTo2D(std::string(), nullptr)` (#4127)
>> * Add `proj_context_set_user_writable_directory()` to public API (#4144)
>> * CMake: for Windows builds, defaults PROJ DLL to be just `proj_${PROJ_MAJOR_VERSION}.dll` (#4167)
>> * Add `toWGS84AutocorrectWrongValues()` method and use it in PROJ.4 and WKT1 CRS import (#4172)
>> * WKT import: add support for Oracle WKT "Albers_Conical_Equal_Area" spelling (#4181)
>> * Limit number of C++ exceptions thrown & caught internally (#4183)
>> * Database: update to EPSG 11.016 (#4241)
>> * CMake: add option `EMBED_PROJ_DATA_PATH` (#4207)
>> * Add SEA Inverse projection (#4211)
>> * projinfo: Add 2 args equivalent to usage of `-s` and `-t` (#4218)
>> * CMake: add TESTING_USE_NETWORK configure option (#4220)
>> * Add `PROJ_ERR_COORD_TRANSFM_MISSING_TIME` and `proj_coordoperation_requires_per_coordinate_input_time()` (#4221)
>> * Add new Conversion "Local Orthographic" (#4228, #4229)
>> * Add data/ITRF2020 with ITRF2020 to ITRFother, and ITRF2020 plate motion models (#4235)
>> ### Bug Fixes
>> * Fix `imoll` and `imoll_o` zone calculations to correct inverse transformations near the "seams" (#4159)
>> * Fix wrong EPSG conversion code for UTM south (#4166)
>> * BoundCRS::exportToPROJ(): handle case of NADCON conus grid (#4168)
>> * `+proj=gridshift`: make projected grids work with `PROJ_NETWORK=ON` (#4174)
>> * `createOperations()`: make it work when transforming from/to a CompoundCRS with a DerivedVerticalCRS with ellipsoidal height (#4176)
>> * Support default context as `nullptr` in `CoordinateTransformer` (#4177)
>> * cct: emit error message and return error code when not being able to open input file (#4200)
>> * Fix race condition surrounding DB reopening during fork (#4231)
>> * `GeographicBoundingBox::create()`: accept degenerate bounding box reduced to a point or a line (#4237)
>> * `createOperation()`: tune so that ITRF2000->ETRS89 does not return only NKG grid based operations but also time-dependent Helmert (#4244)
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
More information about the PROJ mailing list
