[PROJ] PROJ 9.5.0 & PROJ-data 1.19
Kristian Evers
kristianevers at gmail.com
Sun Sep 15 05:19:58 PDT 2024
It’s my pleasure to announce the release of PROJ 9.5.0 and PROJ-data 1.19!
The PROJ release includes a number of updates, as well as a bug fixes.
See the release notes below.
The PROJ-data release adds grids for Greenlandic GLLAT and GLMSL CRS’s.
Download the archives here:
https://download.osgeo.org/proj/proj-9.5.0.tar.gz
https://download.osgeo.org/proj/proj-9.5.0.zip
https://download.osgeo.org/proj/proj-data-1.19.tar.gz
https://download.osgeo.org/proj/proj-data-1.19.zip
/Kristian
# 9.5.0
## Updates
* Database: add constraint for unicity of CRS and operation names (#4071)
* Make a few more functions that accept a `PJ*` to actually acccept a `const PJ*` (#4074)
* Database: Increase consistency in trigger checks (#4080)
* Speed-up `+proj=cart +inv` (#4087)
* Added EPSG:9656 "Cartesian Grid Offsets" operation method, and imported related records (#4094)
* Add a `WKTParser::grammarErrorList()` method so that `proj_create_from_wkt()` can behave as documented (#4108)
* `CRS::stripVerticalComponent()`: Redirect it to `demoteTo2D(std::string(), nullptr)` (#4127)
* Add `proj_context_set_user_writable_directory()` to public API (#4144)
* CMake: for Windows builds, defaults PROJ DLL to be just `proj_${PROJ_MAJOR_VERSION}.dll` (#4167)
* Add `toWGS84AutocorrectWrongValues()` method and use it in PROJ.4 and WKT1 CRS import (#4172)
* WKT import: add support for Oracle WKT "Albers_Conical_Equal_Area" spelling (#4181)
* Limit number of C++ exceptions thrown & caught internally (#4183)
* Database: update to EPSG 11.016 (#4241)
* CMake: add option `EMBED_PROJ_DATA_PATH` (#4207)
* Add SEA Inverse projection (#4211)
* projinfo: Add 2 args equivalent to usage of `-s` and `-t` (#4218)
* CMake: add TESTING_USE_NETWORK configure option (#4220)
* Add `PROJ_ERR_COORD_TRANSFM_MISSING_TIME` and `proj_coordoperation_requires_per_coordinate_input_time()` (#4221)
* Add new Conversion "Local Orthographic" (#4228, #4229)
* Add data/ITRF2020 with ITRF2020 to ITRFother, and ITRF2020 plate motion models (#4235)
## Bug Fixes
* Fix `imoll` and `imoll_o` zone calculations to correct inverse transformations near the "seams" (#4159)
* Fix wrong EPSG conversion code for UTM south (#4166)
* BoundCRS::exportToPROJ(): handle case of NADCON conus grid (#4168)
* `+proj=gridshift`: make projected grids work with `PROJ_NETWORK=ON` (#4174)
* `createOperations()`: make it work when transforming from/to a CompoundCRS with a DerivedVerticalCRS with ellipsoidal height (#4176)
* Support default context as `nullptr` in `CoordinateTransformer` (#4177)
* cct: emit error message and return error code when not being able to open input file (#4200)
* Fix race condition surrounding DB reopening during fork (#4231)
* `GeographicBoundingBox::create()`: accept degenerate bounding box reduced to a point or a line (#4237)
* `createOperation()`: tune so that ITRF2000->ETRS89 does not return only NKG grid based operations but also time-dependent Helmert (#4244)
More information about the PROJ
