[PROJ] Sinusoidal interrupted
Javier Jimenez Shaw j1 at jimenezshaw.com
Tue Apr 1 08:54:18 PDT 2025
Hi
I was looking for the Sinusoidal interrupted projection in PROJ (and later
QGIS)
https://en.wikipedia.org/wiki/Sinusoidal_projection#/media/File:Usgs_map_sinousidal_equal_area.PNG
But I haven't found it. Am I wrong?
What I found is https://proj.org/en/stable/operations/projections/sinu.html,
that is not interrupted.
In case it is not there, would it be worth it to add it? See that this is
one type of projection used to print the covering of a 3D globe.
Cheers
Javier.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20250401/2b3f6caf/attachment.htm>
More information about the PROJ mailing list
