[PROJ] setting default transformation NAD83 CSRS to / from NAD83 Original
Even Rouault
even.rouault at spatialys.com
Wed Apr 9 12:23:14 PDT 2025
Travis,
in EPSG, the grid ON83CSv1 is registered for the transformation between
NAD83 original and NAD83(CSRS) v3. Note the v3 suffix. So instead of UTM
NAD83 CSRS (epsg:2958) you need to use "NAD83(CSRS)v3 / UTM zone 17N"
(epsg:22317)
$ projinfo -s EPSG:22317 -t EPSG:26917 --spatial-test intersects -o PROJ
--single-line -q
+proj=pipeline +step +inv +proj=utm +zone=17 +ellps=GRS80 +step +inv
+proj=hgridshift +grids=ca_nrc_ON83CSv1.tif +step +proj=utm +zone=17
+ellps=GRS80
$ echo 500000 5000000 | PROJ_NETWORK=ON PROJ_DEBUG=2 bin/cs2cs
EPSG:22317 EPSG:26917
Using https://cdn.proj.org/ca_nrc_ON83CSv1.tif
500000.08 5000000.32 0.00
Even
Le 09/04/2025 à 20:58, Travis Kirstine via PROJ a écrit :
> Hi All,
> I’ve been struggling with trying to set proj to use
> ca_nrc_ON27CSv1.tif grid as the default transformation when
> transforming between UTM NAD83 CSRS (epsg:2958) and UTM NAD83
> (epsgL26917) Original.
> In the past I’ve specified the +nadgrids=./ON83CSv1.gsb in the cs2cs
> command but was hoping that I could just set the default value in the
> proj.db to apply the gridshift.
> Is this possible? I’ve run the projsync to pull the new version of
> the grid but still no luck.
> Regards
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20250409/50aaad34/attachment.htm>
More information about the PROJ
