[PROJ] NATRF2022 in PROJ
    Javier Jimenez Shaw
    j1 at jimenezshaw.com
    Thu Apr 24 08:15:34 PDT 2025
Here you have a first version.
https://github.com/jjimenezshaw/NSRS-2022-PROJ
still things to improve and things to add.
It is something to play with. It has a expiry date: when things are
published in EPSG.
Best regards,
Javier.
On Wed, 23 Apr 2025 at 21:25, Javier Jimenez Shaw <j1 at jimenezshaw.com>
wrote:
> Hi
> Some people in the "NGS & CGS Binational Geospatial Software Developers
> Summit" asked about having the new reference systems (and transformations)
> in PROJ.
> They will be there once they are published in EPSG (at least the
> compatible pieces).
> In the meantime we thought that including some of that stuff in an
> auxiliary database could be doable. That would be out of any release, but
> will let some people to test it in PROJ. At least what is doable with the
> current PROJ source code (for instance, the dynamic part of the geoid model
> cannot be represented with the current code).
> I am working on a branch with such auxiliary db. I will write here soon
> telling where exactly.
> It will be completely unofficial, will not be included later in a release,
> and may change at any time. As always, open source, so you can play with it
> if you need/want.
> Cheers
> Javier.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20250424/865b89e4/attachment.htm>
More information about the PROJ
