[PROJ] Big grid files
    Even Rouault
    even.rouault at spatialys.com
    Sun Apr 27 05:43:40 PDT 2025
Le 24/04/2025 à 21:51, Mike Taves via PROJ a écrit :
> There is Git Large File Storage (Git LFS), which has a limit of 2GB.
Yes, but there are billing / bandwidth implications. I remember we had
it enabled, but CI cloning typically exhausted the allowed free bandwidth.
Javier, maybe you can try using gdal_translate -scale X X X X -ot UInt16
-co COMPRESS=DEFLATE -co TILED=YES -co PREDICTOR=2 with the appropriate
scaling values ?
Or gdal_translate -co DISCARD_LSB=X -co COMPRESS=DEFLATE -co TILED=YES
-co PREDICTOR=3  to nullify least signifcant bits of the mantissa.
> On Fri, 25 Apr 2025, 04:37 Javier Jimenez Shaw via PROJ,
> <proj at lists.osgeo.org> wrote:
>     Hi
>     I am playing with the new American geoid model SGEOID2022
>     After compressing with this command (can I do it better?)
>     gdal_translate sgeoid2022.tif sgcomp.tif -co COMPRESS=DEFLATE -co
>     TILED=YES -co PREDICTOR=3
>     I get a 110 MB file (and it is only one band. No velocities).
>     GitHub has a limit of 100MB:
>     https://docs.github.com/en/repositories/working-with-files/managing-large-files/about-large-files-on-github
>     Just to let you know.
>     Cheers,
>     Javier.
>     _______________________________________________
>     PROJ mailing list
>     PROJ at lists.osgeo.org
>     https://lists.osgeo.org/mailman/listinfo/proj
> PROJ mailing list
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20250427/adfb52a9/attachment.htm>
More information about the PROJ
