[PROJ] mismatch between proj release tags and tarballs
Greg Troxel gdt at lexort.com
Sun Apr 27 05:46:54 PDT 2025
This is just a nit and not a big deal, but I noticed an odd mismatch
between the 1.21.0 tag and the artifacts.  I would expect the 'create
release' to have them end up the same.
  - https://github.com/OSGeo/PROJ-data/releases
  - see that the tag and headline is 1.21.0
  - see that the first artifact is
      https://github.com/OSGeo/PROJ-data/releases/download/1.21.0/proj-data-1.21.tar.gz
    but there is also
      https://github.com/OSGeo/PROJ-data/archive/refs/tags/1.21.0.tar.gz
  - in https://download.osgeo.org/proj/ find
      https://download.osgeo.org/proj/proj-data-1.21.tar.gz
pkgsrc is currently pointed at download.osgeo.org.  (I think that's a
feature, not approving of github expecting the world to deal with their
way and have a forge-specific fetch procedure with URLs that are not
trivially machine-generatable from the version, with varying earlier
parts, instead of following traditional norms of a download dir.)
But, the file naming in github and the release page appears consistent.
I don't remember encountering this before, but looking at the release
page on github it maybe started with 1.17.0.
I see in the release action on line 42 that only N.N.N releases are
considered final, when that regexp probably should accept N.N also,
intenndig to omit alpha/beta/rc.  Also that only N.N.N and N.N.NRCN are
used for release action runs.
That's all fine, but it would seem that 1.21.0 should have tarballs that
are named 1.21.0.  (And, unpack to 1.21.0, except that proj-data is
unusual in that it doesn't have such a directory in the unpack.)
I see that this arises in CMakeLists where there is:
set(PROJ_DATA_VERSION_MAJOR 1)
set(PROJ_DATA_VERSION_MINOR 21)
set(CPACK_SOURCE_PACKAGE_FILE_NAME "proj-data-${PROJ_DATA_VERSION_MAJOR}.${PROJ_DATA_VERSION_MINOR}")
but no micro.  So I guess the bug is that either there are micro
versions or there aren't, and if so MICRO should be added to CMakeLists
and if not the tag form in the release action and the tags used should
drop the micro.
More information about the PROJ mailing list
