[PROJ] mismatch between proj release tags and tarballs
    Greg Troxel
    gdt at lexort.com
    Sun Apr 27 11:24:56 PDT 2025
Kristian Evers <kristianevers at gmail.com> writes:
> The one true source for PROJ(-data) packages is download.osgeo.org/proj/ <http://download.osgeo.org/proj/>. The PROJ-data
> archives found there are copied from the GitHub release. That is, the files named proj-data-x.y.z.*.
Thanks; I'll stick with them.
> The 1.2.1.tar.gz file you find in the GitHub release is basically just the repo checkout at that tag
> and put in a tar.gz file. Disregard it. As far as I am aware you can’t get rid of them from the GitHub
> Release page.
> Regarding the version numbers in the files. Yeah, it probably is a bit sloppy. I think we’ve always
> only used major and minor versions in the actual releases (also for previous iterations of the data
> package in the olden days) but somehow all three numbers found their way to the HOWTORELEASE
> document when we started the PROJ-data package. I guess it is more correct but since we haven’t
> yet had an opportunity to patch a previous release I don’t think we particularly need the last digit…
I am agnostic about x.y vs x.y.z but if releases are going to continue
to be x.y, it might be good to adjust HOWTORELEASE.  Perhaps nobody but
be will ever notice though.
More information about the PROJ
