[PROJ] Big grid files
Even Rouault even.rouault at spatialys.com
Sun Apr 27 12:53:39 PDT 2025
> During the summit I asked about the interpolation method. The metadata
> says that it should be biquadratic. The answer was: "for the
> undulation there is almost no difference. But for other magnitudes,
> like vertical deflection, it is more noticeable. However, to match our
> values you have to do biquadratic interpolation"
> Do we have biquadratic intepolation for the geoid models?
If you use the generalized +proj=gridshift method, yes, with the
+interpolation=biquadratic flag:
https://proj.org/en/stable/operations/transformations/gridshift.html#cmdoption-arg-interpolation
> I would be very surprised that they release something at a different
> resolution. Some people asked for a GeoTIFF, and they were reluctant
> (but not completely oposite). They want to minimize the different
> formats and file to deal with (one ggxf for everything)
> But there are other problems:
>  - velocities: the full model, considering time evolution, has a
> velocity component. N_t = N_2020 + (t-t0) * v. The resolution of that
> velocity is different if I checked correctly. And we do not have such
> a model in PROJ. (It will appear in EPSG at some point)
For difference resolution per file, we already have such case with
us_noaa_nadcon5_nad83_2007_nad83_2011_alaska.tif:
$ gdalinfo
GTIFF_DIR:1:/home/even/proj/proj-data-1.21/us_noaa_nadcon5_nad83_2007_nad83_2011_alaska.tif
Origin = (171.958333333333343,73.041666666666671)
Pixel Size = (0.083333333333333,-0.083333333333333)
Band 1 Block=256x256 Type=Float32, ColorInterp=Gray
   Description = latitude_offset
   Unit Type: arc-second
Band 2 Block=256x256 Type=Float32, ColorInterp=Undefined
   Description = longitude_offset
   Metadata:
     positive_value=east
$ gdalinfo
GTIFF_DIR:2:/home/even/proj/proj-data-1.21/us_noaa_nadcon5_nad83_2007_nad83_2011_alaska.tif
Origin = (171.875000000000000,73.125000000000000)
Pixel Size = (0.250000000000000,-0.250000000000000)
Band 1 Block=241x93 Type=Float32, ColorInterp=Gray
   Description = ellipsoidal_height_offset
   Unit Type: metre
> One more thing: I do not expect them publishing the intra frame
> deformation model (IFDM2022). Every time they mentioned it they added
> "Danger!". That leave a feeling of "incompleteness" among the
> audience, as that model is needed for some time dependant
> transformations (like bringing measurements to the frame epoch,
> 2020.0). They will offer it in their webpage somehow.
What about NAD83(2011) to NATRF2022: did they mention something ?
Currently PROJ uses NAD83(2011)->ITRF2020 (EPSG:10334) and
ITRF2020->NATRF2022 (using Euler Pole Rotation).
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20250427/02e5a1f0/attachment.htm>
More information about the PROJ mailing list
