[PROJ] remote proj.db
    Javier Jimenez Shaw
    j1 at jimenezshaw.com
    Wed Aug  6 06:51:37 PDT 2025
Hi
I am working with Will on a wasm version of PROJ, trying to support also
remote grids (using emscripten_fetch).
Do you know if there a way to specify the location of proj.db as a remote
URL? in that case, it would not be embedded in the wasm file itself. (I am
not sure if it does make sense).
Cheers,
Javier.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20250806/d8729da7/attachment.htm>
More information about the PROJ
