[PROJ] PROJ 9.7.1RC1 & PROJ-data 1.24RC1
Kristian Evers kristian at evers.dev
Mon Dec 1 05:48:40 PST 2025
With +1’s from
Kristian
Javier
Even
Thomas
Howard
Charles
Alan
I declare the motion passed.
Expect a release announcement within the next couple of hours.
/Kristian
> On 29 Nov 2025, at 15.16, Alan Snow <alansnow21 at gmail.com> wrote:
> +1 Alan
> On Tue, Nov 25, 2025, 4:08 AM Kristian Evers via PROJ <proj at lists.osgeo.org> wrote:
>> Everyone,
>> It’s once again time for a round of releases of the PROJ and PROJ-data packages. I’ve prepared
>> release candidates for both, which can be downloaded from
>> https://download.osgeo.org/proj/proj-9.7.1RC1.tar.gz
>> https://download.osgeo.org/proj/proj-9.7.1RC1.zip
>> https://download.osgeo.org/proj/proj-data-1.24RC1.tar.gz
>> https://download.osgeo.org/proj/proj-data-1.24RC1.zip
>> The PROJ-data release adds a grids for the
>> * Czech S-JTSK / Krovak East North to S-JTSK/05 / Modified Krovak East North transformation
>> * Norwegian vertical transformation from NN54 to NN2000 height
>> * French RGM23 to IGN 2023 Mayotte height transformation
>> Details for the PROJ release can be found below.
>> Please report any issues you may find with the release candidates, either here
>> on the mailing list or in issues on GitHub.
>> /Kristian
>> # PROJ Release Notes
>> ## 9.7.1
>> ### Updates
>> * Enable transformations_czechia.sql (#4578)
>> * Update to EPSG v12.029 (#4586)
>> ### Bug Fixes
>> * `createOperations()`: fix compound to compound when vertical CRS definition is equivalent but not strictly identical (#4579)
>> * `createOperations()`: fix compound to compound when horizontal CRS of … (#4582)
>> * `projinfo`: make it honour `-k crs` (#4592)
>> * `proj_clone()`: fix insufficient propagation of `FORCE_OVER=YES` (#4595)
>> * `BoundCRS::identify`: fix creation of an invalid BoundCRS (that can cause later crashes) for CRS based on 'NTF (Paris)' (#4601)
>> * WKT/PROJJSON datum ensemble import: allow no members (#4615)
>> PROJ mailing list
>> PROJ at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20251201/6fed8002/attachment-0001.htm>
More information about the PROJ mailing list
