[PROJ] transformation for Greece
    Even Rouault
    even.rouault at spatialys.com
    Sat Feb 15 07:35:39 PST 2025
Javier,
I don't think that can be done directly in PROJ. That would somehow
require a "add" operator using coordinates pushed on the stack. Or maybe
some super convoluted trickery abusing some of our existing operators,
but nothing comes to mind.
No magic then: I would probably write custom code that would create a
grid from ETRS89 to the final CRS (the geographic CRS of it), with
roughly the resolution of the grid in TM07, applying "at hand" the 4
steps to compute the shift in the lat/long space for all grid cells
(using PROJ for some of the individual steps and Python to make the
addition).
Even
Le 14/02/2025 à 17:50, Javier Jimenez Shaw a écrit :
> Hi Even.
> The example in data/sql/transformations_czechia_extra.sql was very useful.
> First I am trying to reproduce the transformation with a pipeline, and
> later I will make the proper operations and concatenated operations in
> the database.
> However this Greek transformation is more convoluted than I expected
> (initially I misunderstood some steps).
> a) First they have a Helmert from ETRS89 (from their realization, but
> I do not care) to GGRS87. So far so good (params are not the ones from
> EPSG, but no problem)
> b) Then they apply the transverse Mercator to "GGRS87 / Greek Grid".
> All fine.
> c) In parallel they project ETRS89 coordinates into a different
> transverse Mercator, called TM07 (not in EPSG; they provide the
> params). The grid with the horizontal corrections are in TM07
> d) the final projected coordinates in "GGRS87 / Greek Grid" are the
> values from b) plus the corrections from the grid in c)
> See that the easting-northing coordinates to get the correction from
> the grid are not the same as the coordinates from b). To make it
> clear, TM07 has a false-northing of -2000 km
> How can it be done in a pipeline? (later to be converted into
> something in proj.db)
> I do not know how to keep the corrections somewhere to be added later
> to the projected coordinates.
> Thanks
> Javier
> On Mon, 3 Feb 2025 at 16:54, Even Rouault <even.rouault at spatialys.com>
> wrote:
>     Javier,
>     you can probably hack around BOUNDCRS in a totally PROJ-specific
>     way by using the "METHOD["PROJ-based operation method:
>     {proj_pipeline_here}"
>     Otherwise having records in the DB will certainly be cleaner.
>     data/sql/transformations_czechia_extra.sql can probably be used as
>     an example of quite advanced transformations, including using a
>     grid referenced in a projected CRS.
>     Even
>     Le 03/02/2025 à 16:26, Javier Jimenez Shaw via PROJ a écrit :
>>     Hi
>>     I am trying to make this transformation (that is not in EPGS). I
>>     do not know how far I can go with PROJ.
>>     (Apparently this transformation is needed to go from the
>>     coordinates used by HEPOS.gr, the Greek positioning system, to
>>     the official -I think- CRS in Greece, GGRS87.
>>     The best is that the transformation would be in EPSG. Do you know
>>     anybody in Greece with the proper contacts? I am happy to talk
>>     with them about it, and help if needed)
>>     Until it is in EPSG, I would like to use PROJ to do it.
>>     The accurate transformation from ETRS89  to GGRS87 is something like:
>>     - apply a Helmert transformation
>>     - Project into a transverse Mercator
>>     - Apply a correction grid. Yes, in the projected system.
>>     - (optional) go back from the projected to the geographic crs.
>>     I thought about several options:
>>     - First option: create a WKT2 with a BOUNDCRS that defines the
>>     transformation. Can it be done in a single WKT2?
>>     - Second option: add the transformation to proj.db. Is it doable?
>>     - Third option: Create "my own grid" file (in the geographic
>>     system) combining all the steps. Of course, it will loose some
>>     accuracy due to the new grid interpolation.
>>     Any clue?
>>     Thanks.
>>     _______________________________________________
>>     PROJ mailing list
>>     PROJ at lists.osgeo.org
>>     https://lists.osgeo.org/mailman/listinfo/proj
>     http://www.spatialys.com
>     My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20250215/9f34647a/attachment.htm>
More information about the PROJ
