[PROJ] Updating our C++ requirement to C++17 for PROJ 9.6
Kurt Schwehr schwehr at gmail.com
Mon Jan 6 07:15:08 PST 2025
I take RFC 3's text as meaning that there doesn't need to be a vote with
this switch, but that it's a nice thing for the person doing the update to
let the list know of the change happening. If the project wants to switch
to C++23, that would imply that a motion is needed.
If that's different from peoples' expectations, we should definitely
discuss.
If it were a motion, I'd definitely +1 for C++17.
On Mon, Jan 6, 2025 at 6:49 AM Howard Butler via PROJ <proj at lists.osgeo.org>
wrote:
> > On Jan 2, 2025, at 5:54 PM, Even Rouault via PROJ <proj at lists.osgeo.org>
> wrote:
> > Hi,
> > Happy New Year!
> > I propose we update our build requirement from C++11 to C++17. This
> should hopefully be unnoticed by anyone using a not too antiquated build
> chain.
> > Initial trigger for this move is explained in
> https://github.com/OSGeo/PROJ/pull/4366. All our existing CI
> configurations already satisfy the C++17 requirement (and one of them was
> already testing C++20 compatibility)
> > I don't anticipate much use of new capabilities for now except perhaps
> replacing our internal::make_unique<> by C++14 std::make_unique<>
> > C++17 has been a build requirement for GDAL since one year and nobody
> complained. Cf
> https://gdal.org/en/stable/development/rfc/rfc98_build_requirements_gdal_3_9.html
> for an analysis of the impacts.
> > This also satisfies https://proj.org/en/stable/community/rfc/rfc-3.html
> which mentions "Keeping a policy of always lagging behind be two iterations
> of the standard is thought to be the best comprise between the two
> concerns", given that C++20 and C++23 are out.
> Is this a PSC motion? +1 :)
> Howard
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20250106/1eb22aa1/attachment.htm>
More information about the PROJ mailing list
